I agree with JayC. The right wheel/tire combo will get you into the 11's. You may not even need a 150 shot. I've done it with a 125 shot. Honestly, if you couldn't run 11's with the 150 shot I would think something was wrong.
i could be wrong but i doubt it..i have this in my car:
Performance:
professional products polished 75mm throttle body
professional products polished upper plenium
professional products polished typhoon intake
diablosport tune customized by jpc
2 1/2 inch magnaflow magnapacks cat back
msd ignition coil packs
hooker long tube super comp headers 3 inch
w/ header wrap
hooker no cats x pipe 2 1/2 inch
mil eliminators
170 amp polished alternator
moroso aluminum expansion tank
v-2 s trim vortech supercharger with aftercooler polished
svt focus fuel pump
diablosport mafia
60 lb high impedence fuel injectors
kenne bell 40 amp boost a pump
180 degree thermostat
mishimoto performance aluminum radiator
fore performance "e series" fuel rails
moroso power steering tank
Suspension/Chassis:
bbk polished strut tower
eibach drag springs with airbag (rear)
lakewood 70/30 shocks (front)
lakewood 50/50 shocks (rear)
upr products shark caster camber plates
upr products bumpsteer kit
lakewood driveshaft safety loop
upr products chromoly k member
upr products chromoly a arms
eibach coil overs 14" springs 175 spring rate (front)
maximum motorsports extreme duty adj. lower control arms
Drivetrain:
4.10 frpp gears
3000 holeshot b&m stall converter
imperial trans cooler
custom jpc flexplate
battery relocated to the trunk with trunk box
flaming river safety battery shut off switch
optima redtop battery
purple royal synthetic 10w 30 oil
transgo performance shift kit
precision greasable universal joint
pa performance deep sump aluminum transmission pan
and im currently running 12.51 at 109.0
__________________
"The Grogan"
as stated by
The Jmac
The MF House Speaker Jazzer
and The Nerd a.k.a. the nice a**hole
__________________
03blkstanggt
bay side mustangs member #022
vortech at 10 psi
multiple add ons view video below
2005 expedition ( no nickname yet, just bought 9/12/09)
bone stock
Performance:
w/ header wrap
mil eliminators
svt focus fuel pump
diablosport mafia
Suspension/Chassis:
Drivetrain:
4.10 frpp gears
I have to ask, is your throttle body going wide open?
__________________
SCT tuned by Greg @ Speedy Dyno
12.51 @ 108 w/ CMS stage II cams
11.35 @ 120 NX
i would like to think its not after seeing everyone running 11s on nitrous for im assuming roughly 1000 dollars where ive gotten 30k invested in my car.
__________________
"The Grogan"
as stated by
The Jmac
__________________
03blkstanggt
vortech at 10 psi
bone stock
I agree. It seems alot of the centri guys aren't running as well as I would think though, you're definitely not the only one. Hopefully when I get a blower I'll have better luck.
So does anyone think High 11's are possible out of Fresh Rebuilt 2V, Headers, 4.10's, Long tubes w/ Full exhaust. and 150 Shot WET? I'm building my engine right now and i'm hopin this will be enough for now with my budget. OH and CAI and 75mm throttle body. 29lb injectors! (all this running drag Radials)
i ran 10s on this exact setup, except i had a 175 shot
