Go Back   MustangForums.com > Ford Mustang Tech > 4.6 (Modular) Mustang > 4.6L General Discussion
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 11-06-2009, 03:53 PM   #11
H0SS302
2001 Ford Mustang
My Garage
Vehicle: '01 GT Vert;
Send a message via AIM to H0SS302
Quote:
Originally Posted by 01MGGT View Post
I'm not so worried about getting the cams out. The timing is my largest concern. I have removed and reinstalled the same cams in a DOHC 4 banger before but that's one chain. Now I will be starting with new cams and new cam sprockets. Maybe I am worried about nothing.
mark the timing chains with paint where there at before u take em off
__________________
Corner Carving > All
H0SS302 is offline   Reply With Quote
Old 11-06-2009, 04:06 PM   #12
01MGGT
Vehicle: 01 MG Mustang GT
Yeah I have done that on 4 bangers in the past. However, I have a windsor so I will be using new cam gears since mine are pressed on...
__________________
Sound clip of my car
http://www.youtube.com/watch?v=UeHmP0A_fxA
01MGGT is offline   Reply With Quote
Old 11-06-2009, 04:11 PM   #13
stangalator
1997 Ford Mustang
stangalator's Avatar
Vehicle: 1997 Mustang GT
Send a message via AIM to stangalator
be careful using the paint method, I did that the first time and I installed my drivers side cam off one rotation (because the the cams are .5:1 rotation and i moved the crank to get the cams to line up) no damage because they were in the right place, just wrong open and close in the cycle... It ran funny and it took me for ever to find out what i did wrong, here is a video i made to see what others though in a past thread.
__________________
PI swapped, LT's, O/R H, Pro 5.0, 24lb injectors, accufab 70mm TB, FRPP 4.10's & sniper SF
241/274
To Be Installed:
MMFLSFC
stangalator is offline   Reply With Quote
Old 11-06-2009, 05:11 PM   #14
H0SS302
2001 Ford Mustang
My Garage
I got lucky.. my 01 has 11 bolt valve covers
__________________
Old 11-06-2009, 11:24 PM   #15
01MGGT
I haven't counted mine just yet. But according to the vin it is a windsor. Also the tranny is t45 so I would say it's a safe bet it will be a windows. I wish it wasn't...would make it even easier. Guess we will find out when I rip into everything. So I need a fuel line disconnect tool and also a harmonic balancer puller huh?
__________________
Old 11-07-2009, 12:33 AM   #16
stangalator
1997 Ford Mustang
I didn't disconnect the fuel lines from the rail, just pushed it to the side, the rubber hoses bend enough
__________________
241/274
To Be Installed:
MMFLSFC
Old 11-07-2009, 02:37 AM   #17
Xemeth
Vehicle: 2002 GT
Send a message via AIM to Xemeth
The cams are really easy to time if you're not degreeing them.
Once the timing cover and valve covers are off:
-Unbolt the tensioners
-Slide the chains off
-Take the chains and fold them in half so one link is on the bottom and top. Mark each of those links.
-Unbolt the cam caps and take out the old cams.
-Turn the crank so that the keyway is at the 12:00 position. Now don't touch the crank from here on.
-Install the new cams.
-Now take the driver side chain and line up the marked link with the dot on the crank gear (the back half of the gear) and slide the top of the chain over the top of the cam gear.
-Now rotate the cam until the other marked link is on the dot on the cam gear. Repeat for the other side.
-Install the tensioners.
-Rotate the motor AT LEAST twice (the cams turn once for ever 2 times the crank turns) to make sure nothing hits.
And you're done. It's really really simple. It's the same for DOHC, except you have to time the intake and exhaust cams to eachother on the heads before timing them to the crank.
__________________
2002 GT, H/C/I 4v.
Xemeth is offline   Reply With Quote
Old 11-07-2009, 03:19 AM   #18
01MGGT
Thanks That helps alot. I am still waiting on my damn cams to come in so I may start the tear down tmrw. I am pissed because the post office may have lost my packages.
__________________
Old 11-07-2009, 05:22 PM   #19
01MGGT
Looks like trusting the vin number isn't a good idea I have 11 bolt valve covers and have those large girdles above the cams. Looks like I have a romeo and will be using that tool to avoid pulling the front cover. Can't wait for my cams to get here. Still fighting with getting the valve covers out of the car however lol.
__________________
Old 11-07-2009, 07:19 PM   #20
WannaBeGearHead
Vehicle: '00 Mustang GT
Cam install guide
__________________
WannaBeGearHead is offline   Reply With Quote
289, 46, cam, ford, gears, needed, pi, pressed, swap, tool, twovalve, windsor
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
