I took my car (04 Mustang GT) to the dealership where I bought it from to get the oil changed last week. This is the second time they have changed the oil. I would usually change it myself but since I got the car though them I get $10 oil changes. Not bad, it beats doing it myself and I save a few bucks. Big mistake !! Now I have a little oil leak/drip. I have had this car for 6 months and it has never leaked a drop of oil. After doing a little inspecting it looks to be coming for the drain plug but I'm not a 100% sure. I can't get under the car far enough to get a good look. I did check the plug to see if it was tight and it was. I will be taking the car back to the dealer to have them check it and hopefully they will fix it for free. I'm sure I will get some b.s. saying is was already like that. Sorry to bore you guys I just needed to rant.
This ad is not displayed to registered or logged-in members. Register your free account today and become a member on Mustang Forums!
the rubber gasket on the plug goes bad after awhile i replace mine every 5th oil change
__________________
A.S.E. Master Tech, Ford Factory Trained Tech, and SVT Trained Tech
D.S.S. 5.1 stroker built by ProLine Race Engines, 200 shot, TCI 4r70w trans, 3200 stall, trick flo heads, stage 2 cms cams, Long tubes, o/r h-pipe, flows, eibach pro-kit, 03 cobra deep dish in black, tuned by Tim Barth at Modular Power House
go to any part store and tell them you need a drain plug for your model car and the gasket will be on it. the dorman(motormite) part # is 090-161. most of your part stores (advance, orielly, autozone, car quest) all carry dorman products. the cost will be around 3 dollars.
__________________
Send me 15 bucks to buy 6 more quarts of oil :P. I'll see if taking pics while the bolt is in shows or not. As a matter of fact I have a vid of my steering rack maybe it shows my bolt.
