Go Back   MustangForums.com > Ford Mustang Tech > 4.6 (Modular) Mustang > 4.6L General Discussion
Welcome to Mustang Forums!
Welcome to Mustang Forums.
Old 11-08-2009, 10:39 PM   #1
2003mustang
Vehicle: 2003, Ford, Mustang GT
Default Camshaft upgrade
Since in a earlier post i have to upgrade my suspension i am also looking at camshafts
http://www.compcams.com/Cam_Specs/Ca...?csid=966&sb=2
those are the cam shafts comp cams i talked to about and they said i should be ok to use on my engine. My Intake manifold is im told the PI version since its a 2003 GT. So here are my questions.
Will the camshafts i have work with my car? car is 2003 mustang gt 4.6 SOHC convertible
Aside from the camshafts do i need to buy new gears and bolts and so forth or will stock work fine? I realize new springs and retainers are in order.
Once installed approx what HP can i expect to gain from putting these camshafts that i linked above?
Also being in the army at FT sill i have access to a auto craft shop for free...except pay for using the bays..and the tools are good from oil changes to complete overhauls on the engines and transmisions and so forth and ASE mechanics work there helping people out and guiding them what to do...so my question i once i have all the stuff i need....are camshafts hard or easy to install nd whats the approx time to install?
__________________
4.10 Ford Racing Gears
AEM Brute Force CAI
Hurst Short Throw shifter
Flowmaster American Thunder Exhaust
2003mustang is offline   Reply With Quote
Old 11-08-2009, 10:42 PM   #2
H0SS302
2001 Ford Mustang
My Garage
Vehicle: '01 GT Vert;
Send a message via AIM to H0SS302
comp cams are the lamest of all the cam shafts. They need to stick with pushrod motors and leave the OHC cars alone. cushman motorsports/hitechs are some of the best on the market. Hitechs are for stock heads and arguable are the BEST cams out for stock pi heads. CMS cams are GREAT all around and good for ported heads.
__________________
Corner Carving > All
H0SS302 is offline   Reply With Quote
Old 11-08-2009, 10:51 PM   #3
2003mustang
HOSS...i saw these
http://www.hitechmotorsport.com/inde...pper&Itemid=85
high performance stage 2..have NO piston or valve issues..so should be safe for me then.
what else do i need aside from the camshafts?
__________________
AEM Brute Force CAI
Old 11-08-2009, 10:53 PM   #4
mrtstang
Vehicle: 2004, Ford, Mustang Gt
These cams will work, but there are better alternatives as mentioned above. You should also check into Bullet Racing Cams. Modular Head Shop has Bullet grind them to their specs. They have a variety of grinds that are very specific to n/a, turbo, blower, nitrous, NPI heads, PI heads, etc...
__________________
2004 DSG Mustang Gt, BBK long tubes, BBK catted h pipe, SSS Terminator Catback, K&N cai, Steeda UDP's, Accufab 75mm tb/plenum, FRPP aluminum ds, Motive 3.90 gear, Alternative Auto custom tune, Steeda Tri-Ax, DD black bullitts w/315's Nitto 555R's, & 100 shot N20. 269/305 na, 373/528 N20
mrtstang is offline   Reply With Quote
Old 11-08-2009, 10:56 PM   #5
H0SS302
2001 Ford Mustang
My Garage
Quote:
Originally Posted by 2003mustang View Post
HOSS...i saw these
A lot of half assers on this forum will tell you not to worry about getting valve springs but its something you SHOULD get. I just ordered the Hitech stage 2s wich require nothing to be put in, but I went ahead and bought new springs and retainers. Since you have a Romeo Motor you do not need to worry about cam gears or n e thing like that.
Cams are all you need(if you go with a cam with </= .55 lifit) but You should also get valve springs.
__________________
Old 11-08-2009, 11:03 PM   #6
2003mustang
okay..so camshafts and springs and the retainers. I was looking into the springs and stuff because your putting new cams in and might as well get teh support stuff for it. Do i need new camshaft gears? would i need i guess called valve covers or lifters or something?
__________________
AEM Brute Force CAI
Old 11-08-2009, 11:07 PM   #7
H0SS302
2001 Ford Mustang
My Garage
you dont need new cam gears, or valve covers. you MAY need new valve cover gaskets tho.
__________________
Old 11-08-2009, 11:34 PM   #8
mrtstang
Depending on far off your stock cam gears are, you would be wise to at least degree them or possibly buy some replacment cams gears that have been reset.
__________________
Old 11-09-2009, 12:09 AM   #9
01MGGT
Vehicle: 01 MG Mustang GT
Correction Hoss... I am pretty sure the cam sprocket bolts are TTY. I need to get the part number myself so I can make a trip to the dealership for them. and I wouldn't say we are half assing if we don't do springs. Some cams simply are mild enough that they do not exceed the limits of the stock springs. Not to mention you aren't going to be revving high enough with a mild cam and stock bottom end to really warrant it in some applications. Not being a smart ass, just saying.
__________________
Sound clip of my car
http://www.youtube.com/watch?v=UeHmP0A_fxA
01MGGT is offline   Reply With Quote
Old 11-09-2009, 12:15 AM   #10
H0SS302
2001 Ford Mustang
My Garage
Quote:
Like iv said before, its like lowering your car on stock shocks/struts. Half assed. Hitech stage 1 cams have the same lift as stage 2s so they cause the same valve spring stress. You agree that stage 2s warrant a spring change but the stage 1s have the same lift.
I dunno I just think when you do something you should do it right and not cut corners.
__________________
03, 2003, 2004, cam, camshaft, camshafts, car, gt, heads, mach, mustang, mustangforums, put, stock, upgrade
Featured Sponsors
New Sponsors
© Internet Brands, Inc.
