Installed My Focus Pump---Problem
Old 11-11-2009, 12:25 AM
turbo2.3stang
turbo2.3stang's Avatar
Default Installed My Focus Pump---Problem
I just installed my Focus pump in my N/A 2000 GT. There aren't any leaks and everything is bolted and connected back the way it was. I put the strainer on that came with the pump and when I put the assembly back in the hat, the strainer sits perpendicular to the way the stock strainer sat. I'm not sure if that causes a problem but the real issue is when I'm getting into the gas and shifting. It feels like it falls flat on its face for a split second---bad enough to jerk me forward. It usually does it from 2-3 and 3-4.
I have read on other sites that the PPRV causes a lot of problems but I think that is mostly for blown applications. Their symptoms are identical to mine though.
I really don't want to yank the tank out again because I have a full tank of gas and I replaced the rubber filler neck seal and I don't want to risk tearing it (unless there is a low possibility of ripping a new seal)
I don't recall the car doing this when I had the stock GT pump but I could be wrong.
I replaced the stock pump because I thought I was having a fuel issue and I already had the Focus pump so I figured "why not"
Anybody know of a cure?
turbo2.3stang is offline
Old 11-11-2009, 12:40 AM
turbo2.3stang
This is the pump: http://cgi.ebay.com/ebaymotors/Svt-F...mZ280393168589
Old 11-12-2009, 07:31 AM
dtkikols
dtkikols's Avatar
did you tune the car so it knows your running the svt pump?
dtkikols is offline
Old 11-12-2009, 08:31 AM
vanquish
vanquish's Avatar
you shouldn't need to
vanquish is offline
mtgldr
02-03-2024 09:00 PM
09-10-2015 08:39 PM
09-08-2015 11:50 AM
Quick Reply: Installed My Focus Pump---Problem
