Underdrive pulleys: Worth it?
Old 11-25-2009, 02:11 AM
blue95stang
blue95stang's Avatar
Default Underdrive pulleys: Worth it?
I have an '02 gt with a pro 5.0 shifter, o/r h, flowmaster catback, 78mm bbk tb and plenum, 373 gears, and a s&b CAI. It is a daily driver and I am getting the magnapack catback, and was wondering if the underdrive pulleys were worth it, especially reading some bad things with running hotter than normal. What do you think? Thanks!
blue95stang is offline
Old 11-25-2009, 02:54 AM
04sonicbluegt
04sonicbluegt's Avatar
i've had mine on for a couple months, and mine does not run any hotter than it did before.
04sonicbluegt is offline
Old 11-25-2009, 08:14 AM
mrtstang
mrtstang's Avatar
It will run fine, and make a small difference in the higher rpm's.
mrtstang is offline
Old 11-25-2009, 08:23 AM
mustangmancp
mustangmancp's Avatar
Not if you want to go FI. Stock ones are needed.
mustangmancp is offline
Old 11-26-2009, 03:06 AM
00infernoGT
00infernoGT's Avatar
if you plan on going F/I in the future, the UP would be a waste of money since you would change back for the blower
00infernoGT is offline
Old 11-26-2009, 10:10 AM
nascrchi
nascrchi's Avatar
Why can't you use aftermaret pullies with a S/C.
nascrchi is offline
Old 11-26-2009, 07:38 PM
_Slowbra_
_Slowbra_'s Avatar
because you dont want to "underdrive" the blower.
_Slowbra_ is offline
Old 11-26-2009, 09:56 PM
school boy
school boy's Avatar
im sorry but i gotta say something about runnin udp and a s/c. if your only running around 10 psi, you jus got to regear the s/c pulley(smaller) and you will be fine.
school boy is offline
Old 11-27-2009, 09:50 PM
_Slowbra_
_Slowbra_'s Avatar
yea but then youre shelling out money for a UDP set and for a smaller pulley for the SC. I'd rather skip the UDP and leave the stockers on for the FI if I planned on it for the future that way i save some $$ for the time being. And if you changed the pulley wouldnt the blower be running twice as much for stock pulley levels of boost?
Old 11-28-2009, 12:14 AM
02stang2113
02stang2113's Avatar
They dont really do all that much... but they are one of the cheaper mods u can do, so why not!?
02stang2113 is offline
Quick Reply: Underdrive pulleys: Worth it?
