Noises....make them stop!
Old 11-29-2009, 07:19 PM
freefallin98
freefallin98's Avatar
Default Noises....make them stop!
I am nearly certain it's the idler pulley. When I am in gear and stopped at a light or something, I can hear is loud squeking and chirping noise. When I put it into N or P, the noise stops. This is the idler pulley, right? If so, how much am I looking at for a replacement one and what do I need to do to replace it? How long can i go if it is the ider pulley?
freefallin98 is offline
Old 11-29-2009, 07:37 PM
JC316
JC316's Avatar
It's probably the idler pulley, but it could be an accessory like the alternator . Take the belt off and spin each accessory and each pulley to find it. If it is an idler pulley, replace it ASAP, I had one break on a 95 Cadillac and it left me stranded.
JC316 is offline
Old 11-29-2009, 08:39 PM
freefallin98
Seriously? I heard these were ok when makign noise? What causes it to make noise? How much would just the pulley be? Is it hard? What do I need?
Old 11-29-2009, 08:41 PM
JC316
JC316's Avatar
No, they start making noise when the bearings are going out. The pulley is pretty cheap, I think it's around $20. I think it's just a 1/2 ratchet to loosen the tensioner off to release the belt and then a 13MM, or 15MM socket or wrench for the idler pulley bolt.
JC316 is offline
Old 11-29-2009, 10:41 PM
freefallin98
Hmm, ok that would be nice. I would definitely be able to change it myself. I thought you had to have an air ratchet to change out pulleys? Can anyone confirm the process of changing one out or have access to any sort of writeup?
Old 11-29-2009, 10:56 PM
freefallin98
http://www.jegs.com/i/Gates/465/38006/10002/-1
I found this one on jegs.com. This will work, eh? Also, do I need to replace a belt too?
Old 11-29-2009, 11:20 PM
JC316
JC316's Avatar
No air tools required. It's just one bolt that holds it on, I have changed it on my mustang before.
Yep, that will work. No, you shouldn't have to change the belt unless it's cracked or frayed.
JC316 is offline
cr620
10-03-2022 10:18 PM
4cylinderplus2
10-09-2020 07:45 PM
IronRaptor
09-09-2015 08:10 AM
Quick Reply: Noises....make them stop!
