broke an intake bolt!!! what should I do?
Old 12-04-2009, 11:34 PM
TimmyGt
TimmyGt's Avatar
Originally Posted by MU71L4710N
before you try to retard strength it.
I didn't retard strength anything. I broke it with hand tools one handed trying to loosen it like I did all the rest of the bolts, this one just ended up breaking instead of coming loose. what do you guys not understand about the fact that old bolts will sometimes break from age and not brute force? do you not realize the heat and stress they go through after being on there for 13 years? sorry I can't afford a car from the new millennium like you can and that I just have to work with what I own!
TimmyGt is offline
Old 12-04-2009, 11:41 PM
motorman524
MF Informant
motorman524's Avatar
The easy out will work better if you use a drill bit and drill into the broken bolt a little first. I wouldn't just dig right in with the easy out only.
motorman524 is offline
Old 12-05-2009, 09:51 AM
mickeysc
mickeysc's Avatar
Just for future reference
besides blasting the screw/bolt, I have had some success when I tighten a little to break it loose. Then I take it out.
mickeysc is offline
Old 12-05-2009, 07:27 PM
kenv
kenv's Avatar
easy out and hose it down with some PB blaster before you do it.
next time a bolt wont cooperate spray some PB blaster on it before you try to retard strength it.
PB blaster is some good stuff. Works great if you let it soak in for awhile.
kenv is offline
Old 12-18-2009, 01:06 PM
TimmyGt
TimmyGt's Avatar
I drilled into the bolt and tried to use the easy out. it wouldn't budge so I just drilled all the way through the bolt and went to a larger drill to drill out the rest of the bolt. I got it out now and want to know what I should do about that bolt. do I just try a new bolt and see how messed up the threads are or spend the $ on a tap set I'll only use the one time? anyone able to tell me what size tap I need for this?
TimmyGt is offline
Old 12-18-2009, 01:54 PM
Tim99GT
Tim99GT's Avatar
Well if you drilled out the entire bolt, then the hole is now larger than what it was before. Using the same size bolt wont do any good. You will have to get a tap, tap the hole and use a new bolt that is the same size as the tap. They arent expesive or anything. And there is no such thing as buying a tool and only using it once. I'm pretty sure somewhere down your life you will need a tap set....
Tim99GT is offline
Old 07-25-2023, 01:10 PM
Gameboychris
Gameboychris's Avatar
What drill bit would you use
Gameboychris is offline
maestro1024
09-21-2015 02:40 PM
04stangman
09-17-2015 01:45 PM
jim2015
09-14-2015 08:09 PM
J.casone400
09-12-2015 10:01 PM
Quick Reply: broke an intake bolt!!! what should I do?
