00 gt vert auto exhaust and intake
Main reason is because headers are a real pain to install and aren't too cheap. So if you are going to do it, you want to get something that will actually net some gains. Shorties don't net as much hp as long tubes.
Screw the headers its a big mess. Do a pypes or/ x 180$, magnaflow magnapack catback 490$, mil eliminators which will stop your computer from throwing the check engine light 60$, 02 sensor wire extension 35$ it will extend from the x-pipe to over the trans and do 410 gears depending on which shop 300-600$. And if you still decided you want cold air intake Jlt fender well and thats 230$. You will see better gains with cold air intake if you do a 75mm t-body and upper plenum 230$. www.americanmuscle.com
Edit: Actually- I'm pretty sure a car with Long Tubes will fail emissions in any state...
nope as i posted b4 i passed with my lt's and high flow cats here in Nj. It doesnt matter which position there in as long as there burning the emmitted gases that they check for.
YoungStangsMan
09-05-2015 07:01 PM
mryeah256
08-28-2015 02:01 PM
