Wiring Q's: Termi wing/trunklid on my '99. Which wires do I splice into? (PICS)
Old 12-06-2009, 06:40 PM
STREETFIGHTER50
STREETFIGHTER50's Avatar
Default Wiring Q's: Termi wing/trunklid on my '99. Which wires do I splice into? (PICS)
I was told everything was plug & play, but I guess it's different for the '99 harness (4 wires, the Cobra LED has 2). I'm out of town at my sisters so I don't have the test light. Heres some pics below. As u can see they're totally different plugs. Which ones do I need to splice into? The two center wires? Green & black like the two coming from the Cobra LED??
STREETFIGHTER50 is offline
Old 12-06-2009, 08:07 PM
StriderTacticaL
StriderTacticaL's Avatar
I've got a termi wing on my stock trunklid. I bought an OEM Cobra trunklid harness from Ford cause I wanted everything to be plug and play, otherwise it wouldn't be.
My friend recently put on a complete termi trunklid on car too, and all we did was cut the plug off the GT harness and stuck the wires into the brakelight plug coming off the termi wing. Yes cut off the GT plug and stick the green and black wires into the corresponding holes on the cobra plug. He chose not to cut off the cobra plug because one day he may buy the cobra trunklid harness later.
StriderTacticaL is offline
Old 12-06-2009, 09:23 PM
STREETFIGHTER50
Yeah I don't really wanna cut the gray plug off the Cobra LED wires. How much did that Cobra trunklid harness run u?
Old 12-07-2009, 02:00 AM
StriderTacticaL
It was about $62 from my Ford dealership.
Just out of curiousity, did you measure and drill all the holes for the termi wing? I did the extra 3 on the middle of the top part but didn't do the 2 on the bottom because it was hard to measure. I tried as best as I could to get it straight, and for the most part it is except the whole spoiler seems to be sitting about 3mm or so too high.
Is your's anything like that?
Old 12-07-2009, 09:00 AM
soccerman002
soccerman002's Avatar
I had to replace the third brake light on the Saleen wing that came mounted to my Cobra when I bought it. The brake light had no harnesss, so I just did what the guy above mentioned and stuck the two wires from the brake light into the harness then wrapped the harness with electrical tape.
Once it's done, it's done. I wouldn't waste money on the other harness, unless for some odd reason you plan on undoing the wiring very often.
soccerman002 is offline
Old 12-07-2009, 12:01 PM
STREETFIGHTER50
I was lucky to pick up the whole trunklid/wing from a friend. He's parting out an '04 Cobra same color as my car. I shouldve cut the other plug off the '04 Cobra trunklid harness, but thought it was all the same from what I was told by everyone.
jwog666
12-27-2021 08:09 PM
Urambo Tauro
10-05-2015 09:37 PM
Matt's 95 Stang
10-05-2015 07:16 AM
Dathan
10-05-2015 05:52 AM
cbird1177711
09-02-2015 08:51 PM
Quick Reply: Wiring Q's: Termi wing/trunklid on my '99. Which wires do I splice into? (PICS)
