Painting Harmonic balancer?
Ok so I have all my crap apart to replace a timing chain guide and have been trying to clean the crap out of everything I can get to now. The front timing cover is coming clean pretty easy but my crank pulley/harmonic balancer is rusted as hell and is going to look pretty crappy in an otherwise tidy bay. Is it ok to clean off the rust with like a wire wheel on a drill and then paint it with just some black krylon or something? It may sound dumb but I just didn't know if it would effect it doing it's job in anyway.
I am curious as to why anyone believes wire brushing and painting the balancer would affect anything--at all--other than make it look better?
Here is a photo of the Steeda UDP set and a stock balancer (happens to be a 2006 set, but that's irrelevant); note that the Steeda pulley/balancer is painted. Ford's is not only because it's cheaper to not paint it...
I merely want to get rid of the rust and make things under the hood cleaner, look better while i have it all apart.
What possible difference could a coat of paint--probably adding an evenly distributed whopping 0.005% to the balancer's mass (and less than that if the rust layer is removed, offsetting the mass of the paint) make in the balancer's ability to dampen crankshaft harmonics?
I have for many years believed that there no such thing as a stupid question; nonetheless asking "Is it ok to clean off the rust with like a wire wheel on a drill and then paint it with just some black krylon or something?", as did the OP over 4 years ago, is pretty damned close to being one.
I am asking "Why is anyone concerned that cleaning and painting the harmonic balancer might create some problem--any problem?"
I had not considered that as part of the question--of course it will chip eventually, sooner rather then later if you do not prep it properly.
After wire brushing the damper clean/degrease it with denatured alcohol, 2 or 3 three times (you can wash it with dish washing detergent and hot water first, when dry use the alcohol once or twice).
I have found Krylon's Rust Tough to be about the best there is for painting things like the engine pulleys--beating out RustOleum's Stops Rust by a long shot.
Apply 3 or 4 coats to do it right. If using the Krylon you need to apply additional coats within 20 minutes to 2 hours; or wait 48 hours if you miss that window.
Do it like that and it will look good for several years...
mungodrums
09-28-2015 10:54 PM
LivingInThePast
09-16-2015 12:20 PM
