How to remove rear bench - Page 2 - MustangForums.com
Old 01-08-2010, 01:25 AM   #11
motorman524
MF Informant
motorman524's Avatar
I'd look for the tabs or buttons, whichever they may be first.
motorman524 is offline   Reply With Quote
Old 01-08-2010, 01:29 AM   #12
itsdaveonline
Quote:
Ill look around tomorrow, im assuming they would just be slightly underneath the seat, just out of visibility?
itsdaveonline is offline   Reply With Quote
Old 01-08-2010, 01:34 AM   #13
motorman524
MF Informant
That's where I'd look.
Old 01-08-2010, 01:38 AM   #14
0949er
0949er's Avatar
yes they are small run your finger along the bottom of the cushion you should feel them. I almost remember them having a opening in the middle so you can pull (or push, dont remember)
0949er is offline   Reply With Quote
Old 01-08-2010, 01:21 PM   #15
vanquish
Yes when you find the tabs just under the front of each rear seat, I used a screwdriver to press in the white tab/button. As you're pressing that tab in, lift up and down on the front of the bench seat until it releases out of the pin.
This was a PITA for me you'll probably fight it for a while but it will come out.
vanquish is offline   Reply With Quote
Old 01-08-2010, 01:55 PM   #16
masterofthepuppets99
masterofthepuppets99's Avatar
thats so weird! my back seat has no locking tabs or anything, just two pins on the seat that fit into two holes on the car itself. for me its as simple as lifting up.
masterofthepuppets99 is offline   Reply With Quote
Old 01-08-2010, 02:22 PM   #17
Tim99GT
Tim99GT's Avatar
I had used a flat head screw driver to do mine. The tabs are located in the "middle" underneath each seat.
Take a screw driver, slide it between the seat and floor pan.
Then slide it side to side to help loacate the tab.
Once you have found it, push on it with the screw driver and lift the seat cushion up.
Its as simple as that.
The first time is a pita if you've never done it before, but once you figure out how it works, it literally takes 2 min to do each seat.
As for the backing of the seats, if you have to remove them, the easiest was is to remove the entire rear seat mount.(big black square metal piece) then take it( along with the backs of the seats) out at the same time. You will need a reg socket set for this.
Tim99GT is offline   Reply With Quote
Old 01-08-2010, 02:25 PM   #18
Tim99GT
Tim99GT's Avatar
Quote:
The piece the pins go into is the tab that everyone is talking about. This tab "latches" to the pins when they are inserted. There is a "button/tab" that you have to push in that lets the pins go. Just like a buckle on your seat belt.
Old 01-08-2010, 02:34 PM   #19
02stang2113
02stang2113's Avatar
Quote:
Originally Posted by itsdaveonline View Post
Wait so do i need to push the seat back more and lift it out? Or do i need to find these tabs first? It seem's like there is no definite answer. It almost seems like i need to find these buttons underneath the seat to release it, but yet there underneath so i cant access it! Haha just like inventing a lightbulb before electricity. But im sure its simple. I played around with the seat for about a minute today and gave up.
Oh and ive actually had two alpine type R subs sitting around for about 2 years. Time to put them to some use I'm so close to getting everything ready for the subs. Ive actually been in the cold wrestling with these new headlights i got from AM, but one of them wont fit for **** or im doing something wrong, but the subs were on the back burner until i could find a sure way of just routing the power cords under the seats.
cool... its gonna bump.
02stang2113 is offline   Reply With Quote
Old 01-08-2010, 02:38 PM   #20
lizzyfan
Underboss
lizzyfan's Avatar
lizzyfan is offline   Reply With Quote
Cam and rear end gear questions Ryan Fitzpatrick New Member Area 3 09-14-2015 03:21 AM
Classic Auto Air Feedback fastbackford351 Classic Mustang General Discussion 2 09-12-2015 10:42 AM
Upgrading to handle slicks? Info needed Dragonus18 4.6L (1996-2004 Modular) Mustang 8 09-09-2015 02:21 AM
Steeda & Nitto Tire Testing NT555 G2 - Great Photos Inside!! tj@steeda Steeda Autosports 0 09-08-2015 12:50 PM
Boston S85 Speakers - Pair Doogie65 Parts For Sale 0 09-06-2015 03:55 PM
1998, 2004, 96, back, bench, body, cushion, ford, gt, mustang, part, rear, removal, remove, seat
