Trick Flow Twisted Wedge or Patriot Performance cylinder heads
Trying to decide between trick flow twisted wedge or patriot performance cylinder heads for my 5.1 stroker modular engine. There is not much of a price difference so Im more concerned about performance. What kind of numbers will I see with each and what is a good cam choice for the trick flow heads?
One of last months Mustang mags (either Mustang & fast Fords or 5.0) tested a new edge with a few upgrades, including the heads, full exhaust, tune, ??, and were somewhere near 100 HP upgrade. It might be worth reading. I believe it was a used new edge GT that was stock at the start.
Deff Ported trickflows. with those extra cubes and rpms im going to assume you'll be running, you need all the air you can get. But IMO if your going FI then it wont matter as much unless you plan to do 800+hp
Luke9222
10-22-2015 11:55 PM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
99, cobra, cylinder, cylinder heads, flow, ford, genii, heads, modular, mustang, patriot, patriot performance, trick, trick flow, twisted, twisted wedge, wedge
