600hp fuel system
Old 01-24-2010, 06:09 PM
liljojo4711
liljojo4711's Avatar
Default 600hp fuel system
when it comes to fuel and everything that goes along with it, im ignorant. no idea what i would need for a 500hp car. im guessing new fuel rails, 60lb injectors, 1 or 2 ford gt fuel pumps. other than that i have no clue. im sure there are fittings and stuff i will need and anything else or suggestions would be appreciated.
liljojo4711 is offline
Old 01-24-2010, 06:57 PM
Gearhead559
Gearhead559's Avatar
from what i have been learned, is that a focus pump and a boost a pump would do the job with 42's. but i like to over due things.(esp with the fuel system) hell they say stock cobra pumps can handle that.
but lets see where this goes first
Gearhead559 is offline
Old 01-26-2010, 10:28 AM
neubstang
neubstang's Avatar
Call Fore precision they have the large fuel rails, and a fuel hat that will support up to three fuel pumps. I am running a Fore hat with twin Ford GT pumps, and the Fore rails with the return fuel system. You will also need a fuel regulator, Y-block and all new fuel lines run to your fuel tank. I have an 01' GT and it was tricky re-routing both lines, from the front to the back. I would not run them alongside the stock fuel lines, as it is too close to the driveshaft. It's probably going to run you close to $3,000 to run this system, but it is well worth the money if you are looking to make big power. If you call Fore yourself, they are very helpful with information.
neubstang is offline
Old 01-26-2010, 09:27 PM
doughboy4.6
doughboy4.6's Avatar
My setup is dual cobra pumps ,boost a pump ,#60 injectors and stock rails and my car is making 555rwhp but is starting to lose fuel at the end.
doughboy4.6 is offline
Old 01-26-2010, 09:40 PM
liljojo4711
im going with a terminator fuel tank with stock pumps, 40 amp bap and 60lb injectors. later i might add a modified fpdm. should be good to about 550hp.
09-16-2015 07:53 PM
SteelerNation82
09-16-2015 07:11 AM
angeljoelv
SVT Forums
09-10-2015 09:12 PM
09-10-2015 08:39 PM
uedlose
09-10-2015 03:30 PM
Quick Reply: 600hp fuel system
