sheet metal vs Fiberglass Hood
where does it say that latemodelresto's hood is sheet metal? i would think they used fiberglass also....i dont know that for sure though, did you call them?
of the two, i would order from latemodelresto....if you have any issues im sure their customer service will be willing to help you out more than some random ebay seller
"Our reproduction hoods are crafted then shipped directly from our warehouse to you. We offer nothing but the best sheet metal for your Mustang"
I guess they saw their problem and changed the description, i just send them an email since they are closed, ill let you know
I would doubt VERY much that an after market hood would be fabricated from sheet metal, the cost for the dies for making such a large assembly would be staggering.
And if it were steel it would weigh 3 times more than the stock hood, and 4 times more then an after market glass hood...
I would have said if someone was dumb enough to do a sheet metal hood, there would be no advantage because you would be adding serious weight to the car over the fiberglass hood.
is there a difference i mean fiberglass is fiberglass right i dont know? does it have a difference in quality?
Hand laid construction uses woven or knit glass cloth that is placed and smoothed into mold, usually in multiple layers of cloth and resin.
The laminated construction is much stronger, however for something non-critical like the hood of a car chopper-gun fabrication is fine.
Here's a good WIKI article...
