Need some opinions on performance upgrades..Help Please
hey guys i have an 02gt and am looking to upgrade my injectors,fuel rail and coil wires.. here are my current mods. bored .30 over,manley forged pistons + rings, scat forged h-beam rods,stage 2 ported pi heads, manley nex tec springs, custom grind comp cam, kook long tube headers,bbk x-pipe,flowmaster exhaust,4.10 gears,90 shot of nitrous,upr cold air intake,70 mm throtle boy accufab.. i have stock injectors fuel rail and coils..was going to buy msd coils a fuel rail and injectors.. what size lines should i go with on the fuel rail? also i am going to run the 90shot a few passes and plan on uping it to 125 or 150shot at the track? what is going to hold up good? i was thinking 30lb injectors? to small to much? also fuel line size reccomendations? also what else am i mising that would make this run better? and will the mods i wanna buy open it up more? right now it has a sct tune to shift at 5800rpm and is ready to back on dyno and get tuned to **** points 6800rpm. i wanted to do these mods first though. thanks for all opinions and suggestions!
okay so iam going with 30lb injectors, intake manifold do u no of a differance or a better intake the elderbrok or trick flow? and im going to gett he mach 1 pullys..could u help me out on them on where to find and what brand? and i would much rather b safe and get it tuned for 6500rpm ill c what tune guy says thanks alot
edelbrock intake for your setup since you have new rotating assembly and heads/cams and can spin it high. and you better get the thing retuned for the shot that you plan to run. Your setup can probably handle lets call it probably right around a 200 shot if you wanna go that big. I'd stick with the 150-175 if they make a 175. What clutch you running??? And you might want to run a 42lb injector. mrtstang runs 42's with a wet kit both on and off the bottle and they work good for him. Might wanna try those.
okay so basically i should get 42s, what i am conserned about is ill pertty much only b spraying at the track so ill b motor on street is the 42s going to b fine on street with no spray? and if i understand correctly ur saying 30lb with dry kit isnt going o work unless i have a bigger fuel rail? as far as intake goes im going to get elderbrok....and i have a Centerforce Stage 2 clutch
like stated before, as long as your tuner knows what he's doing, you'll be fine. mrtstang is running 42lb injectors on his car on and off the spray and when hes not on the spray, he is running just full bolton's, so you should be fine with h/c/i.
