Door Handle Shave
Use the key to open the trunk and climb through the back seat and open doors duhhh!!! while it does look kool, I agree with strider. If you skinny like me then theres no problem in climbing through trunk but if your big ur "assed out"
The kits usually come with an emergency unlock button that you hide on the underside of the car.
You can do two things, either use a manual pull cable that's hidden or do what I've been planning on do, and that's make a Hot battery terminal outside of the car. It's an easy way to jump your car or get the doors open.
I paid 120 for my kit about 5 years ago. (Never installed it.) Definitely what ever you do, don't cheap out and make sure the poppers are heavy enough to always push the door away from the striker, even in cold weather.
Last edited by Sxynerd; 03-02-2010 at 02:46 PM. Reason: wow....I can't believe I'm educated with that low level of grammar. Fook me I'm stupid sometimes.
You can do two things, either a manual pull cable hidden or do what I've been planning on do, and that's make a Hot battery terminal outside of the car. It's an easy to jump your car or get the doors open.
