Fuel system help: trouble after Focus pump
It came off again. I am almost positive. I was just finished the blower and had drove it around some and then I was going through base housing to go off base and grab some food and the speed limit was like 15mph so I was doing about 20 and she started bucking and **** again. Pulled it off the road and no workie.
Popped the hood and pressed in the pressure relief on the pass side fuel rail and no pressure at all. My buddy said we should take a die to the pump and put some threads on it to give the hose something to bite to? We even used a normal band clamp this time so we knew it would grab and ran it way tight.
Will be ordering the correct fuel line today just so I know that isn't causing any problems!
TfcCDR
09-14-2015 12:08 PM
09-08-2015 11:50 AM
