how much RWHP with these mods
Old 04-01-2010, 03:26 PM
quickndslick2
Banned
quickndslick2's Avatar
Question how much RWHP with these mods
ok so i recently dynoed my car and made a meesly 246 rwhp and 275 tq i have bbk cold air intake 70 mm tb and plenum, bbk long tube headers, and full exhaust, steeda underdrive pulleys , diablo sport predator and 373 gears, i just recently orderd comp cams stage 2 cams, and cam gears, my question is what rwhp will i be looking at with the new cams and tune? my goal is atleast 300hp what do u guys think??
quickndslick2 is offline
Old 04-01-2010, 03:30 PM
mrtstang
mrtstang's Avatar
No, in all honestly probably more like 270-275 rwhp and 280-285 rwtq.
mrtstang is offline
Old 04-01-2010, 03:40 PM
tdcalhoun89
tdcalhoun89's Avatar
yeah, you're going to need a hell of a tune to get 300rwhp with what you're working with... good luck though
tdcalhoun89 is offline
Old 04-01-2010, 03:53 PM
quickndslick2
Banned
damn
Old 04-01-2010, 03:56 PM
MU71L4710N
MU71L4710N's Avatar
stage 2 cams you should be hitting 300rwhp tho i thought? unless your on an auto. from what ive seen stage 1 cams will hit around 290-295 on a full bolton PI gt, and stage 2's will hit right around 300.
thats with a dyno tune also.
MU71L4710N is offline
Old 04-01-2010, 04:09 PM
teej281
4.6L Section Moderator
teej281's Avatar
not so much. with stage 2 cams, the norm is to see right around 290rwhp and with a helluva tune you'll find 300rwhp barely. But for that you would need something like CMS/Hitech stage 2's, which you would need ground intake valves or new intake valves to make work without having to worry about ptv clearance.
teej281 is offline
Old 04-01-2010, 04:18 PM
quickndslick2
Banned
i got the comp cams stage 2 XE270AH with the valve springs beehive kit the valve spring steel retainers and the adjustable cam gears
cliffyk
TECH SAVANT
cliffyk's Avatar
Are you just running a preset tune from the Predator? What octane did you select, have you tweaked anything else?
Do you have a wide band O2 system? You can't really do much tuning without one...
cliffyk is offline
Old 04-01-2010, 04:21 PM
teej281
teej281's Avatar
I really need to get a wideband o2 with an analog gauge for my car.
teej281 is offline
Old 04-01-2010, 04:25 PM
quickndslick2
Banned
yea only the 93 octane tune thats it he tweaked the rev limiter my shift points and thats about it not much he could do on the predator i will have a custom tune done when i finish witht the install tho
Quick Reply: how much RWHP with these mods
