200-250 for a new PI manifold. You will need to tap in a hole for your other coolant sensor (99+ have one, you have two).
If you already have the NPI with the aluminum crossover just unbolt it and put it on the PI manifold and save 15 bucks from not buying a tap(for some reason the sensors thread pattern was the most expensive tap)
Ive got a set of romeo PI heads complete (valves,cams,springs) that I would let go for 150
sent you a PM, get at me I'd like to buy ASAP!
Why bother with the swap and use stock cams you ask? The car is my dd for one, I don't want to buy new cams (don't have cash), don't want to do a dyno either...and last but not least cause the 96 mustang GT has 215 hp stock, I would be adding 50 hp for $150 + mis. parts you can't beat that!
