oil pressure gauge install question.
Old 05-03-2010, 08:42 PM
My1stGT
My1stGT's Avatar
Originally Posted by 0949er
a_penguin, thanks for all ur help BTW.
My1stGT, has your car triggered any CEL light of any kind?
From what I can find, you might trigger one of these three ODBII errors:
P0196 - Engine Oil Temperature (EOT) Sensor Circuit Range/Performance
P0197 - Engine Oil Temperature (EOT) Sensor Circuit Low Input
P0198 - Engine Oil Temperature (EOT) Sensor Circuit High Input
Those three have to do with the EOT calculating your oil temp. I'm assuming that it will throw an error after it realizes that it cant get a temperature.
no i havent thrown any codes as of yet and have had it on a month or so now ,but as a_penguin did i may go ahead and hook the stock up as well ,just in case ya know. let me know how your install goes
My1stGT is offline
Old 05-03-2010, 09:16 PM
0949er
0949er's Avatar
will do. Just consider some errors don't necessarily throw a CEL, so if you had your car scanned, one of those *might" come up, even though they don't necessarily trip a CEL. Either way, if it has been like that for a month now, I wouldn't even bother. If there was a problem, you would of known by now.
0949er is offline
Old 11-16-2012, 09:16 PM
Yordan Medina
Yordan Medina's Avatar
hey i was hoping if you could help with the install of a mechanical oil pressure gauge i really need help and if theres anything i might need to know about this..thanks
Yordan Medina is offline
Old 11-17-2012, 11:05 AM
cliffyk
TECH SAVANT
cliffyk's Avatar
What does the EOT (Engine Oil Temperature) sensor, which the GTs do not have anyway, have to do with the oil pressure switch?
Regarding the switch, all it does is link to the instrument cluster; it is not monitored by the PCM that I can find...
cliffyk is offline
Old 04-27-2014, 10:36 AM
VTX1800N1
VTX1800N1's Avatar
I know this is an old thread, but I found it when searching for a location to install an oil pressure gauge. Can one of you detail the parts and location of the install?
VTX1800N1 is offline
Old 04-30-2014, 08:05 PM
CobraFrenzy
CobraFrenzy's Avatar
theres an unused capped bung on the oil cooler, u can get the parts you need from a hard where store
CobraFrenzy is offline
67LimeCoupe
11-25-2015 08:55 PM
yurizx6r
09-07-2015 06:40 PM
toastintx64
08-29-2015 05:12 PM
jjwinel78
08-17-2015 03:34 PM
yurizx6r
08-11-2015 07:50 AM
Quick Reply: oil pressure gauge install question.
