Post Info and Pics of Your 99-04 Mustang's Stance
#22
#23
i've installed MM c/c plates on both of my mustangs and they are fantastic! awesome quality, no noise, clean install, and awesome instructions. i would not hesitate at all to recommend them to someone.
#24
Only pic I have so far, I will get some good ones in a week or 2.
99 IRS with Eibach pro-kit with top isolators pulled, bottom isolators in.
Springs have settled a little more, I need to get a tape measure to it to check the drop.
#25
Hey thanks bro. Hey man I will be around your way to get my car dynoed tuned after I install the V1. A guy in Waynesville will do the install and then I will be getting it dynoed in High Ridge. I think the place is called Mustang Muscle. Ever heard of it? If so any word on there services? Thanks bro..
#26
low as ****. the mufflers drag sometimes hahaha. need to get a straight shot from the x pipe to the mufflers cuz that piece dips down too
Picture:
Front Wheel Size (Height x Width): 18x9
Back Wheel Size (Height x Width): 18x9s
Type of Wheel: saleen
Spacers: i wish
Caster and Camber Plates: Billet Shark Caster Camber Plates
Front Tire Size: 265-35-40s
Back Tire Size: 265-35-40s
Type of Tire: maxxis
Springs: H&R SS
Amount of Drop: ~ 2 inches
Shocks and Struts: stock
Panhard Bar:
Upper Control Arms:
Lower Control Arms:
Anything Else: its too low.. need some custom exhaust work now :/ LOL whatever
#27
in my sig. stock suspension minus the 21. lowering springs in front and 1.5 in the back. Tire size is 18x9 and 18x10 275 35 R18 and 295 35 R18 and yes without CC plates i have massive inside tire wear. Hope to fix that this summer.
#30
Picture:Cut springsBest pic I could find right now of it being lowered....
Front Wheel Size (Height x Width): 18x9, too heavy
Back Wheel Size (Height x Width): 18x10, even heavier
Type of Wheel:Black Bullitts, DD, way too heavy lol
Spacers: None
Caster and Camber Plates:none, but I have Camber bolts
Front Tire Size: 255/40/18
Back Tire Size: 285/35/18
Type of Tire: Potenza's!
Springs:Cut Bullitt Springs, forgot how much I took off
Amount of Drop: About 2 inches?
Shocks and Struts:Stock
Panhard Bar:None
Upper Control Arms:None
Lower Control Arms:None
Anything Else:Looking for a different Wheel set up, going to lower the car some more...
