Is 400 hp possible to obtain with a 2v 4.6 if i keep it N/A
Old 05-24-2010, 05:52 PM
0949er
0949er's Avatar
Originally Posted by 03mustangerGT
Those Cams sounds pretty sick i must say dude but how is the install for the vortech sc fairly easy or something that a mechanic should do for me? I raced my buddys 6.0 gto the other day and got my *** handed to me, his gto is stock 400hp(not sure if that's at the crank or wheels) but i got to beat him so i can talk **** about how much he spent on his car compared to me ?
Me and 2 other guys did the install in about 20 solid hours. We had to fab up a lot of stuff, but that is mainly because we also installed a front mount intercooler with the blower. You can run a non-IC system that is a fairly "easy" install, (if you have any mechanical ability). You could get into a pinch pretty easy though if your not careful. (like messing up the tap on the oil pan etc, breaking a critical part, etc)
check this out too, its a semi-documentary on my install: T-Trim Build w/ FMIC
0949er is offline
Old 05-24-2010, 06:09 PM
trailor
trailor's Avatar
to beat a stock GTO, you def won't need 400hp. theyre a much heavier vehicle (~3900 lbs i believe) and can't fit as wide of a rim/tire combo as you can. http://www.allfordmustangs.com/forum...t-bullitt.html <-- thats a link on how to get your car into the 12's on a N/A setup. stock GTO's with the 6.0 run low 13's. problem solved
trailor is offline
Old 05-24-2010, 06:13 PM
03mustangerGT
03mustangerGT's Avatar
Thanks for the info guys... you think after just cams and heads i could keep with my buddys gto then? How much NOS can you spray with factory short block?
03mustangerGT is offline
Old 05-24-2010, 06:24 PM
0949er
0949er's Avatar
cams+heads+full bolt ons will put you right at about 300 rwhp. That might be enough to keep up with the gto, dont know for sure though. I would defiantly invest in a set of 4.10s to help you though.
0949er is offline
Old 05-24-2010, 06:29 PM
03mustangerGT
i just put the 4:10s in about a month ago and love them.... Now is having an auto gunna kill me when it comes to racing my friends gto w/6sp manual? I had the tranny gone through professionally and drop 3g's into it so its way better then average 4r70w!
Old 05-24-2010, 06:38 PM
trailor
trailor's Avatar
theres plenty of tuning modules that will allow you to modify your tranny's shift points, shift firmness, etc. etc. i would recommend looking into a tuning program. i would also recommend checkin out that link i posted, of how to get in the 12s. the guy on there did not have heads or cams, and was not pushing 300whp
trailor is offline
Old 05-24-2010, 06:44 PM
03mustangerGT
yeah that was a great post for sure but the guy had a 5spd not an auto, idk if matters one way or the other but off the line i cant really control my launch at a certain rpm like you can with a manual. Whats your a opinion on stall converters? can they be used on a daily driver car?
Old 05-24-2010, 07:31 PM
MineralGrey
MineralGrey's Avatar
Originally Posted by 0949er
best bang for the buck, vortech kit that you part together for yourself.
ultimate bad-*** blower, kenne-bell twin screw.
the only downside to this is finding a decent used head unit, I have been looking for 2 years and I either lose on the bid or they are over priced for used head units.
MineralGrey is offline
Old 05-24-2010, 07:41 PM
0949er
0949er's Avatar
u gotta look other places then ebay then. I got a T-Trim blower, fmic w/ all piping, and 42lb injectors for $1600.
I found it literally by googling "vortech t-trim for sale," becoming members on some random forum to get a guys number, and the rest is history. People are getting deals on these things right and left... you just gotta look else ware. they are out there I promise.
what price are you looking for?
0949er is offline
Old 05-24-2010, 08:02 PM
SVTeeshirt
SVTeeshirt's Avatar
corral.net poweradders section, up for sale ALL the time.
SVTeeshirt is offline
Quick Reply: Is 400 hp possible to obtain with a 2v 4.6 if i keep it N/A
