Nitrous help
Old 07-25-2010, 05:46 PM
Red__03GT
Red__03GT's Avatar
Default Nitrous help
So i have been looking into doing a 100 shot recently and i have the money for it now and I'm just wondering if you guys can give me a list of what i need. Im gonna go with the HSW dry kit. Now along with it i need a window switch a fuel pump and what else? I'm gonna hold off for now on the heater. How necessary are bigger injectors? I know this has probably all been answered before but I can't find it all in one.
Thanks
Red__03GT is offline
Old 07-25-2010, 06:01 PM
GTRACER88
GTRACER88's Avatar
Just wondering why dry... when they have a bad a** wet plate kit for $400-500..? Plus you don't need to change your injectors...
GTRACER88 is offline
Old 07-25-2010, 06:54 PM
mrtstang
mrtstang's Avatar
I've been running a NOS dry kit for around 3 years now and it has been extremely reliable. Not a single problem yet. You will most definitely need larger injectors though.
mrtstang is offline
Old 07-25-2010, 07:40 PM
WannaBeGearHead
Go Texas!!!
WannaBeGearHead's Avatar
Bigger injectors and fuel pump to run a dry shot. I would invest in a bottle heater, preferably a self regulating one. Also, a window switch like you said above. Everything else I think will come in your nitrous kit.
And 1 step cooler plugs. NGK TR6 are a good plug that many people, including myself, run when using a power adder.
WannaBeGearHead is offline
Old 07-25-2010, 08:48 PM
GTRACER88
GTRACER88's Avatar
If your heart is set on a dry shot then these guys are correct. Larger injectors (42 would work well), window switch (if your a manual and you want extra safety), and one step colder plugs. Bottle warmer and remote bottle openers are not really needed but a bottle warmer is a really good investment!! It will make your hit a lot harder!
Old 07-25-2010, 09:23 PM
PurpleIcedGT
PurpleIcedGT's Avatar
And don't ever forget...."Nitrous is like a hot girl with an STD, you always want to hit it, but don't want to face the consequences...." So set up that nitrous kit right the first time and youll be good to go man!
PurpleIcedGT is offline
Old 07-25-2010, 10:50 PM
Red__03GT
Red__03GT's Avatar
thanks for all the help guys... is there a reason i should be swayed to a wet shot?
Old 07-25-2010, 11:49 PM
WannaBeGearHead
Go Texas!!!
With a wet shot żou don't need bigger injectors or a better fuel pump. Also, if your running just a 100 shot you don't need a tune for it as where with a dry you do. I would never run a 100 shot without it being tuned though.
People also say a wet kit hits harder than a dry kit.
Old 07-26-2010, 04:23 AM
GTRACER88
GTRACER88's Avatar
Yup. Nailed it. Plus a wet kit with the plate atomizes the nitrous better making a better distribution in the combustion chamber. Its always good to get your A/F checked but my "Custom Dyno Nitrous Tune" was the stock tune... It was a huge waste of money.
Old 07-26-2010, 06:59 AM
josh.davis
josh.davis's Avatar
I vote for the wet kit!!!!!
josh.davis is offline
Quick Reply: Nitrous help
