Shocks & Struts
Old 07-27-2010, 03:31 PM
01redstang
01redstang's Avatar
Originally Posted by teej281
Thanks, question... should i do the quad shock while I'm at it?
01redstang is offline
Old 07-27-2010, 04:07 PM
teej281
4.6L Section Moderator
teej281's Avatar
Nope, just get some MM HD or XD lower control arms. Quad shocks are there to prevent wheel hop and adding good lower control arms will make quad shocks not needed.
teej281 is offline
Old 07-28-2010, 08:27 PM
hpwrestler220
hpwrestler220's Avatar
I have the tokico HP's on my car and i think they are a pretty damn good dampner for street use while greatly improving performance...
If you are on a budget and have/are going to lower the car ~1.5, get the HP's (blues)
If you are looking for more of a performance oriented setup, go with the bilstein HD's, but the pricetag comes with it
hpwrestler220 is offline
Old 07-28-2010, 11:16 PM
liljojo4711
liljojo4711's Avatar
if u arent corning carving or drag racing it really doesnt matter. doubt u will really tell a difference. i bought some kyb-gr2 shocks and struts off ebay for $180 shipped and they are 10 times better than my stockers. i have 1 coil cut all around on my springs and the ride was terrible with the stock setup. so i got the fox shocks/struts and it made a huge difference. i definitely cant justify spending $200-300 more just to drive around on. just my .02
liljojo4711 is offline
Old 07-29-2010, 08:00 AM
teej281
teej281's Avatar
I can when they will last so much longer and are a much sturdier design. Have you ever seen the strut shaft of a Bilstein strut? If you havent, I suggest looking it up. And the fact that you have fox body shocks and struts is probably why you dont have any problems with them. Cutting one coil off of the spring will put it in the lower end of the opperating range and buying the fox body shocks and struts will allow you to lower it more without putting the dampeners out of the opperating range, but if you got those same shocks and struts in new edge form, they would probably suck a fatty. I'll stick to my guns and say you get what you pay for with suspension parts.
teej281 is offline
Old 07-29-2010, 09:19 AM
Jazzer The Cat
Retired Moderator
Jazzer The Cat's Avatar
Natistang, never talked to you on the forums but I like you already! lol your .02 just got added into my $1...so now we got $1.02 for bilstein hd's!!!
I'll give you $1.04 for Koni's
Jazzer The Cat is offline
Old 07-29-2010, 09:27 AM
teej281
teej281's Avatar
If it were before June 30, you would have that much and more for Koni's Jazzer...back when they were actually cheaper than the Bilsteins. But now the Bilsteins are cheaper again and I think that they are both great dampeners. So my vote is still going towards bilsteins.
teej281 is offline
Old 07-29-2010, 09:46 AM
devongarver
devongarver's Avatar
Jeez I wish i could make up my mind....I keep trying to wait until I have the money to do a UPR K up front and coil overs at 4 corners...but that is just so far off and in the mean time I need replacement shocks...gayness.
devongarver is offline
Old 07-29-2010, 10:00 AM
teej281
teej281's Avatar
$50 for those Monroe shocks man...BNIB. Just to hold you over til your goal are more feasible. lol
teej281 is offline
Old 07-29-2010, 10:14 AM
devongarver
lol...crud...I just hate to go through the process of changing them out along with my rear suspension as well..only to do it all again. How good of performance handling can honestly be achieved with a set of lowering springs and matching shocks? I also have full heim jointed rear control arms. Baseline stuff on top. I don't want to lower it much because my road is gravel...
Quick Reply: Shocks & Struts
