Valet Switch? help please
ive tried contacting them and they gave me a super undetailed description of where it is. i was under my dash for like 30 min just grabing wires and looking behind stuff. Does anyone have some help full advice. im laying on my back with head toward the petals looking up. Ive had a 4 channel amp with a 7" double din installed so i think i have ALOT more wires than normal under there. keep in mind its a convertible
i believe you are looking in the wrong place, stay closer to the fuse box or under the steering wheel...if not there pull the kick panel off on the drivers side, like the piece of plastic where the hood popper is..could be behind that or shoved under the carpet even
I have a 2001 svt cobra. The valet switch is located on the right side of the brake pedal. It's a little toggle right above the brake switch. You have to look carefully. My car got stuck in PATS mode and wouldn't start. It overrode it and the car started. The theft switch still blinks when your driving. It'll save you allot of money. and at the end of the day just reach under and switch it back this will help secure it. This should help anyone else who is having problems with the same type of car
as mine or any other ford. KRUDOG
