Is this bad for my car? COME IN QUICK!
Teej -- thats a LOT of money for me to move my wheels forward.. I don't have money for that even though it would make the car look 100x better. My drivers side is MUCH worse than the passenger side.
I dont understand how you can have a 17x9 w/ 275/40 and not rub if you are lowered!
Soldier -- roll your fenders my man.. Get a fender roller and a heatgun and go to work. My one tire is all cut up. I had to roll those b*tches asap before they got f'ed up when i first got my new tires.
Sounds like its no big deal.. It's gettin slammed and i am going to pray it maintains a decent ride quality.. Hopefully we can get these things cut to spec in 1 or 2 tires so we dont have to keep rippin everything apart.
Pics to come tomo if you guys want! Jk, pics to come anyway whether yas like it or not.
hp.... start with yanking the ISOS (if haven't already). This should give you approx. 3/8" drop and is easily reversable if issues arrise. This will NOT effect spring rate, so ride quality will virtually be un-effected and will test some of your rubbing issues.
As for rubbing on the liner, mine look like Swiss cheese, so don't worry about that there. Besides, I think that the bushings are likely tweaking a bit differently than they would on just a drop. If not, then you would rub EVERY time you had that much turn on a larger bump... do you?
Jazzer
Jazzer
Also your car was at a weird angle with the suspension compressed with one side jacked up and your dad sitting on the car with a 50lb weight. Once you get it done and aligned, you'll be fine. Just do eet!!! And sorry I haven't despised to your pm yet. Front bilsteins are still on the car. Should be off soon though.
Jazzer and Teej - You guys are right. The tires were just at a weird angle with the suspension being as fubarred as i had it last night with my dad and the 50lb weight sitting on it haha.
I just got home from slammin the car. Making a new thread now! I don't rub..
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
