Gear swap: what am I getting into?
I have decided I am going to go to 4.10s in my 2003 GT auto. I want to stay away from the engine for now (may or may not do a swap later on), and this seems like one of the best performance increases per buck I can get. Any objections to that?
So, what kind of hell am I getting into? My business partner and I have plenty of tools to do any mechanical work, but what about the other odds and ends that come with modding a newer car? Any programming to be done?
Thanks in advance!
Thanks in advance!
For your auto I would strongly consider 4.30s.. that ish would own.
As far as a gear swap is concerned, as long as you have the correct measurement tools to dial in the necessary locations you should be good.
Youll need some better tires, a decent suspension and a tune to fix the speedo(you dont need a tune but ur gonna want one later on..a speedcal is wasted money).
Do you have a press? Slide hammer? Bearing race drivers? Powerful impact gun? e8 inverted torx bit? Dial indicator? Air hammer with miscellaneous chisels?
I could go on, but if you say no to any of the above, dont attempt it
I don't have to do anything with the transmission in terms of shift points, etc.?
4.10 is the lowest I will go, so as to not harm my fuel economy. I have pretty much figured out that I can get about the same or better with 4.10s, provided I keep my foot out of it and don't drive like a goon (might be easier said than done!).
Thanks for all the help so far!
KingRando
10-02-2015 08:06 AM
junior04
09-28-2015 10:53 AM
