Newest update on the build - Page 2 - MustangForums.com
Old 11-14-2010, 06:35 PM   #11
lizzyfan
Underboss
lizzyfan's Avatar
Quote:
Originally Posted by oxfordgt View Post
Those look like cloyes hex adjust gears. Sure hope you got them after they fixed the problems with them.
That issue was well over 2 years ago, he got them recently
lizzyfan is offline   Reply With Quote
Old 11-14-2010, 07:45 PM   #12
WannaBeGearHead
Go Texas!!!
Quote:
Originally Posted by 97stanger View Post
i even have .060 clearance.
Wow, that is a lot of clearance. I'm all for a safe amount of clearance but why not put bigger cams in there? .060" seems like you are leaving a good amount of power on the table.
WannaBeGearHead is offline   Reply With Quote
Old 11-14-2010, 07:53 PM   #13
teej281
4.6L Section Moderator
teej281's Avatar
Probably doesnt even need that big of a cam to make the power that he wants to make really.
OP, is that the vacuum tree on the back of the plenum? Or where to you have your vacuum lines for the intake tract pulling from?
teej281 is offline   Reply With Quote
Old 11-14-2010, 08:37 PM   #14
97stanger
these grinds are the exact same specs as VT stage 2 blower cams, so basically just went from a stage 3 to a stage 2...also the stage 3 is way out of wack with rpm range, so this should put me in the rpm range where i want to be
I just got these cam gears a few months ago..
97stanger is offline   Reply With Quote
Old 11-14-2010, 09:27 PM   #15
oxfordgt
oxfordgt's Avatar
What heads do you have and what is in your shortblock?
oxfordgt is offline   Reply With Quote
Old 11-15-2010, 07:11 AM   #16
97stanger
MMR stage 3 heads, cobra crank, Manley 18cc pistons, manley forged h beam rods, arp 2000 bolts
Old 11-15-2010, 07:17 AM   #17
Bladerunner
Bladerunner's Avatar
I know two people that had PTV contact issues with the HiTech Stage 2 cams
and it damaged their pistons and valves.
I'm not surprised you had PTV contact issues with the CMS Stage 3 blower cams
they are overkill for your set up anyway.
Bladerunner is offline   Reply With Quote
Old 11-15-2010, 08:27 AM   #18
97stanger
^ after getting the ptv contact i realized and am happy that it actually happened b/c like you said they are complete overkill. And now I have a custom grind that will put me where I want to be
Old 11-15-2010, 08:29 AM   #19
teej281
teej281's Avatar
97stanger, where did you put your vacuum tree at on your plenum? Is that it on the back of the plenum?
Old 11-15-2010, 09:30 AM   #20
mustangmancp
mustangmancp's Avatar
Yea can you tell us how you set up ur 6061...because im still confused on how to even make it work w/ all the vacuum lines, egr, and everything else.
mustangmancp is offline   Reply With Quote
Starting Issue svfetter 5.0L (1979-1995) Mustang 9 10-05-2015 12:39 PM
Hot Lap: 2015 Roush RS3 Test + Build a Supercharger! - AmericanMuscle.com AMAlexLazarus AmericanMuscle.com 0 10-01-2015 10:21 AM
2005 to 2013 Front end swap Build threads... the5 2005-2014 Mustangs 3 09-19-2015 07:13 PM
First Impression 2015Ecoboost New Member Area 3 09-17-2015 02:48 PM
whats needed to swap a 4.6L into ratrod rksnow1 Motor Swap Section 0 09-14-2015 09:46 PM
46, 97, dual, fuel, glenns, gt, install, warlboro
