Newest update on the build - Page 3 - MustangForums.com
Old 11-15-2010, 08:33 AM   #21
teej281
4.6L Section Moderator
teej281's Avatar
You're the reason why I asked cp. lol
teej281 is offline   Reply With Quote
Old 11-15-2010, 08:35 AM   #22
mustangmancp
mustangmancp's Avatar
^^well thank you sir...always got my back!
mustangmancp is offline   Reply With Quote
Old 11-15-2010, 05:33 PM   #23
Chris98Gt
Chris98Gt's Avatar
He has it setup like stock except there is no egr provision. If you look at the stock plenum it will have the two ports on the front and the one on the back.
Chris98Gt is offline   Reply With Quote
Old 11-15-2010, 07:03 PM   #24
97stanger
+1, its just a stock vacuum setup minus egr, everything will go exactly how it was i shouldnt need any vacuum tree or anything
97stanger is offline   Reply With Quote
Old 11-20-2010, 07:05 PM   #25
97stanger
Got a lot done today...
got valve covers on
timing cover, crank pulley, tensioner, motor mounts, plugs, oil filter...now I'm just trying to figure out all of these vortech idler/s/c bracket and whatnot with the spacers, takes some time, here she is as it sits:
Old 11-20-2010, 08:22 PM   #26
lizzyfan
Underboss
lizzyfan's Avatar
A Fram oil filter, shame on you Mike
lizzyfan is offline   Reply With Quote
Old 11-20-2010, 10:46 PM   #27
97stanger
thanks for picking up the important parts of the build Fred, thanks a lot bud! :P
Old 11-21-2010, 08:49 PM   #28
97stanger
got a ton more progress, every GI joe 8 rib conversion on except power steering, bracket/blower, lines run, pretty much all thats left is wiring/vacuum lines, coils/wires, just little odd/ends:
Old 01-20-2011, 09:14 PM   #29
97stanger
Well, havent been keeping you guys up to date:
heres the past 2 months...
Motor as it sits, just about ready to go in the car:
15x4 pro stars w/ Kumho Powerstar 165/80/15's:
Lakewood safety loop
FRPP aluminum driveshaft
1000hp fuel system from glenns performance, includes:
sumped tank
dual walbro gsl392 pumps
fuel filter
y block
fpr
fuel lines
all fittings/clamps
AIS stage 2 trunk mount setup, tri nozzle w/ progressive controller..running one 3gph jet pre blower and two 4gph jets pre throttle body:
Motor is ready to go in, all parts are bought..just need to physically get the motor in the car so I can get everything all set up! Dont see why it wouldnt be all ready to go come early February
Old 01-21-2011, 09:43 AM   #30
school boy
school boy's Avatar
im very impressed! great job man!
school boy is offline   Reply With Quote
Starting Issue svfetter 5.0L (1979-1995) Mustang 9 10-05-2015 11:39 AM
Hot Lap: 2015 Roush RS3 Test + Build a Supercharger! - AmericanMuscle.com AMAlexLazarus AmericanMuscle.com 0 10-01-2015 09:21 AM
2005 to 2013 Front end swap Build threads... the5 2005-2014 Mustangs 3 09-19-2015 06:13 PM
First Impression 2015Ecoboost New Member Area 3 09-17-2015 01:48 PM
whats needed to swap a 4.6L into ratrod rksnow1 Motor Swap Section 0 09-14-2015 08:46 PM
46, 97, dual, fuel, glenns, gt, install, warlboro
