Vortech + meth or IC Kenne Bell
If things work out for me in the near future, i'll be doing either a IC 2.1 KB or a Vortech S-Trim w/meth. Looking at running maybe around 10-11lbs of boost, and maybe 400-430 rwhp. I'm just curious what you all think would be better for my application. With the mods in my sig (minus the N20) which setup do you think would be better for me? Money won't be an issue when the time comes either. Do any of you know which setup would be more consistant, and suffer less possible heat soaking issues?
Overall, i enjoy a twin screw setup more, but with my 3.90's and pushing 400+ rwhp, i wonder if much of that enjoyment will be left in a smoke show.
When you look at the prices of the kits, you see that the hellion single turbo kit is about $1000 more expensive, but you need to be aware of whats causing that.
With the hellion kit, you get full tubular front suspension from k-member to coilover kit and c/c plates.
Also, if you were to get the hellion turbo kit, you would be able to sell your current longtube headers and catted midpipe, which would help with funds, you could sell your mhs cams, which would be ideal in both instances because you will blow your boost out the exhaust ports with n/a cams on any f/i car, and use your stock cams, which work really well as either a blower cam or turbo cam.
Plus, as everyone knows, you'll make more power on less boost with the turbo kit than you would with either supercharger setup.
Just some food for thought MRT!
Well, to be honest i really don't want to change the gears. For whatever reason i just really like them, and don't want to redo something that i've already done. With that being said i think i'd be a little worried with the KB and especially a tubo.
I never really considered a turbo setup. I'm not really familiar with them. That's something i might look more into though. Also from what my tuner tells me (and Nick) my MHS cams would be fine with either blower at around 10psi. Not sure how that would apply to a turbo. They're not ideal of course, but they both had mentioned that they would be better than the stock ones at lower boost levels.
The consensus i'm getting so far is either a tubo or KB. I appreciate the thoughts and opinions guys. Please keep them coming.
Yea, my friend that switched from a 125 hit to a D1 Procharger running like 8psi and he likes the spray better but is too lazy to swap it back over and paid too much for the s/c kit so he is in a sucky situation.
