GOOD TUNER FOR NITROUS
Old 01-14-2011, 06:40 PM
99bluestang
99bluestang's Avatar
Talking GOOD TUNER FOR NITROUS
Im about to put nitrous on my GT and im thinking of buying a tuner to adjust the timing to be safer, whats my best option? SCT, Diablosport...
btw.. its 1-1.5 degrees per 50hp shot right?
99bluestang is offline
Old 01-14-2011, 06:47 PM
99bluestang
...btw ill take out the Jet performance chip, obviously
Old 01-14-2011, 07:22 PM
PurpleIcedGT
PurpleIcedGT's Avatar
I'd go with SCT....
PurpleIcedGT is offline
Old 01-14-2011, 07:24 PM
WhiteFoxGT
Resident Ford Troll
WhiteFoxGT's Avatar
How big of a shot are you planning on running? Wet or dry kit? If you have a wet kit and dont spray over 100 then you can run the stock tune with 93 octane and some TR6 plugs. No need to buy a tuner
WhiteFoxGT is offline
Old 01-14-2011, 07:55 PM
TRUEBLUE3934
TRUEBLUE3934's Avatar
I hate to be a killjoy, but I would strongly suggest you get a custom tune done if you really want to be "SAFE." Nitrous can be an awesome power adder, but only if you do it right. It is not worth a trial and error approach to tuning it yourself.
Just my 2 cents...
BTW, I am comtemplating adding some spray for 1320' trips. One of my concerns is the cost of another custom tune for it. The cost to add it just seems to be a little more than I want to spend to add a kit to my ride. Not to mention the $50 bottle fills each time I go to the track.
GOOD LUCK with your new power mod!
TRUEBLUE3934 is offline
Old 01-14-2011, 08:05 PM
mrtstang
mrtstang's Avatar
I know some people run up to a 100 shot (usually wet) without a tune, but i just wouldn't do it. In fact i decided against doing the self tuning route, and went with a custom dyno tune. I've been running the sauce this way for around 3 years now, and haven't had a single issue.
That's just my take on the issue.
mrtstang is offline
Old 01-14-2011, 10:58 PM
H0SS302
H0SS302's Avatar
I would buy a wideband o2 and the sniper special forces tuner. Instant win.
H0SS302 is offline
Old 01-15-2011, 12:40 AM
WhiteFoxGT
Resident Ford Troll
WhiteFoxGT's Avatar
It only takes 1 hiccup... you could have the safest tune on earth and bad things can and will happen. Thats the downside to power adders unfortunately. Im just letting the guy know the easiest (and cheapest) way to get his car goin fast, safely. I shoulda said to wire in a window switch with his setup. spray from 3-5800. With a tire you'll be low 12s all day night and weekend
Old 01-15-2011, 02:41 AM
99bluestang
Well actually i did buy a zex window switch, the kit is a zex wet kit, and i did buy tr6's. Im also about to get forged pistons and maybe rods... What shot could i go with? Considering i adjust the timing...
articman
06-21-2018 11:45 PM
SSRFUZZY
Members Other Vehicles
01-06-2016 08:22 PM
Luke9222
10-22-2015 11:55 PM
mungodrums
10-07-2015 04:01 AM
Quick Reply: GOOD TUNER FOR NITROUS
