I replaced my stock balancer with a set of underdrives a year ago when my stock balancer failed. Now I just got a vortech with 2 different pulleys one is a 3.60 and the other is a 3.30. Can I just run the smaller pulley on the supercharger or will the boost be to low? Anyone tried this or should I just get a good quality sfi approved damper?
i would switch back if i was you. it can be done but you can only go so small on a s/c pulley before it starts slipping. say you wanted to run a 3.60 s/c pulley with a factory gt pulley system. i think underdrive pulleys run 15% underdrive. 15% of 3.60 is 3.06. its not recamended to run any lessthan 2.90 pulley because of slippage. so you see, it ca be done but your kinda stuck with that setup. your call man
And put more wear on the blower than needed? Its too easy change back to stock sell the udp kit.
what are you talking about??? the smaller pulley brings the s/c back up to the proper rpms as is theres no u/d pullies used. there will be no extra wear!
Oh so the udp's actually slow down the belt speed. I just saw throw a smaller pully on so I thought spin faster(not thinking about the udp's) which creates more wear.
Yes, if you have an UDP on the crank, you'll need to make up for it with a smaller pulley on the blower to get it spinning the same speed. It's not going to be any different (assuming you match % change) than a stock crank pulley and a larger SC pulley.
