Urethane strut mounts and iso harshness question
Old 02-14-2011, 04:58 PM
Armydad
Armydad's Avatar
Default Urethane strut mounts and iso harshness question
Hey all,
Well on top of all the engine work I have to do, I also have all new suspension parts, (springs, control arms, struts etc.) and I am trying to decide if I want to go with poly bushings or stick with the rubber. If you have installed poly strut mount bushings and front and rear spring isolators, could you pls give me an idea of the ride harshness and noise level with the poly as opposed to rubber.
I am not looking for a rally car in the corners, just a little better handling. The polys' are actually cheaper than the good rubber kits, so if it not too stiff I may go with them. Any info will be appreciated.
Thanks
Armydad is offline
PullTab
10-30-2015 08:46 AM
67STANGX2
09-24-2015 12:29 PM
warwickbass
09-20-2015 04:51 PM
robjh22
Suspension
09-08-2015 12:47 PM
Quick Reply: Urethane strut mounts and iso harshness question
