NEW CLUTCH INSTALLED!!!
Old 03-03-2011, 09:38 PM
Dudewright0715
Dudewright0715's Avatar
Default NEW CLUTCH INSTALLED!!!
i just got my car back from the dealership. i had the Ram HDX clutch kit installed but used a ford TOB and Pilot Bearing...got a question my clutch pedal feel has always seemed kinda short..
.and now it seems shorter..but my best friend has a 02 gt and i have late 01 gt and he has the same clutch kit as me but his clutch feels way different..like his feels longer ...like you have to push farther...mine feels ver short like 2 inches and its on the floor...
whats up with that???
thanks
Dudewright0715 is offline
Old 03-03-2011, 09:43 PM
Repzard
Repzard's Avatar
thanks
Sounds like your buddies could be a pedal adjustment kit installed or cable is worn on yours.
Did you have the cable replaced?
Do you have a aftermarket cable adjustment kit installed?
These matter on pedal hieght and clutch grabbing to start.
Good Luck
PS.. Break in that clutch right
Repzard is offline
Old 03-03-2011, 10:45 PM
Repzard
Repzard's Avatar
Originally Posted by Bladerunner
Congrats on your new clutch I felt the same way when I
had my Centerforce Dual Friction clutch installed.
I hope when you had you new clutch installed they replaced
your clutch cable.I recommend going with the Ford OEM clutch
cable because it is the most durable to use.Do you have a aftermarket
clutch cable,clutch quadrant,and firewall adjuster?
Bet it took some thinking to come up with your opnion\answers to his question..
Do you just copy peoples opnions\answers to think you know Mustangs?
When your pictures are dealership photos or google photos of a car you say you own
Back to thread ..sorry ask your friend if he has a aftermarket adjuster,start there
Repzard is offline
Old 03-03-2011, 10:58 PM
Dudewright0715
damn lol..i dont think they did replace the cable.... i think mine is worn...is this bad? like since they already installed the kit how much of a hassle is it to replace the cable?
thanks guys
Old 03-03-2011, 11:07 PM
Z28KLR
Z28KLR's Avatar
Here's the instructions from the MM page, pretty comprehensive and also includes installation of quadrant and adjuster which are relatively inexpensive so you might as well do those too at the same time if you can.
http://www.maximummotorsports.com/co...ch/MMCL-11.pdf
Z28KLR is offline
Old 03-03-2011, 11:14 PM
Dudewright0715
thanks man! that shows everything..lol quick question ..if all i did was change the cable would that give me a longer pedal feel? i mean in mine now i bearly let off at all and it goes like jumps..lol i kinda would like a little play in it...
Old 03-03-2011, 11:15 PM
Repzard
Repzard's Avatar
^ I agree. Really should replace cable with clutch kit install for POM anyways.
As for how to tell if cable is bad,not really sure other than wear you can see or lost of play in peddle movement when push down before you feel tension.
Someone else may chime in with better example.
Good Luck !!!
Repzard is offline
Old 03-03-2011, 11:18 PM
Repzard
Repzard's Avatar
Id say it would help for sure.as for pedal hieght id go with quad and adj kit and call it fixed.
Repzard is offline
Old 03-03-2011, 11:25 PM
Dudewright0715
lol sounds good to me man mabey i should just take it back and tell them i want the cable and quad replaced ..do you think with a factory new quad it woul make my pedal higher?
Old 03-03-2011, 11:49 PM
Repzard
Repzard's Avatar
I wouldnt replace it with a stock (Ford) one. Harder to adjust pedal with stock one.Go aftermarket on the quad\adjuster.You'll be happy
Repzard is offline
mtgldr
02-03-2024 09:00 PM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
raleigh05GTO
09-04-2015 07:09 AM
Emblazoned
09-03-2015 10:45 PM
Quick Reply: NEW CLUTCH INSTALLED!!!
