engine swap
Old 03-07-2011, 05:32 PM
richmustang1880
richmustang1880's Avatar
Default engine swap
its time for a new motor i have 190xxx on my 01 gt. i dont know which direction to go 5.4 2v or 4v or a 4.6 4v. either way i want close to 300 rwhp. i have found all 3 motors, mark VIII 4.6 4v, navigator 5.4 4v, expedition 5.4 2v all for $600-900. im looking for any suggestions i dont have a large budget something like 2400 including the engine but, not including a little i set aside for replacing the head gaskets, oil pump/pickup, spark plugs.. all the little things i know i might need.
richmustang1880 is offline
Old 03-08-2011, 07:53 AM
NeedStangSpeed
NeedStangSpeed's Avatar
If you don't have a large budget, or a complete donor car, I'd suggest sticking with the same thing you have, because swapping a 5.4 anything will nickle and dime you to death. If ther motors you are looking at are complete, you may skate by with a little luck. But with the 5.4 you'll need to modify or change your x-pipe for sure. I'd go with the 4.6 4 valve though if a swap is a must but it should take you over your 300HP goal easily. Just my .02 though, I'm sure you'll get a lot of support for the 5.4 4 valve as well.
NeedStangSpeed is offline
Old 03-08-2011, 09:06 AM
WhiteFoxGT
Resident Ford Troll
WhiteFoxGT's Avatar
skip the 5.4, it'll cost a small fortune and you wont be able to rev it. I'd go with a c-head mach motor or 99-01 cobra. Bolt ons and LTs will give you over 300rwhp
WhiteFoxGT is offline
Old 03-08-2011, 09:14 AM
H0SS302
H0SS302's Avatar
A small fortune for a 5.4? Hardly..
You can pick one up for next to nothing, and its a direct swap in minus the adapters for the intake and getting a midpipe to fit. More torque and a set of cams/intake away from being able to yield good power in the upper rpms.
Doing a 5.4 swap is one of the easier motor swaps for this car.. if you guys are saying that will nickel and dime you... then pretty much everything will. Its probably one of the best bang for your bucks mods out there if you can do the swap yourself.
H0SS302 is offline
Old 03-08-2011, 09:55 AM
WhiteFoxGT
Resident Ford Troll
WhiteFoxGT's Avatar
Stick with your 5.4 swaps then, I'd rather have a 4v
Old 03-08-2011, 09:58 AM
school boy
school boy's Avatar
i vote for you to do a 4v for sure. 4.6 or 5.4 is up to you. either one shouldnt be much different cost wise. there are several threads on 4v swaps and 5.4 swaps
school boy is offline
Old 03-08-2011, 10:17 AM
WhiteFoxGT
Resident Ford Troll
WhiteFoxGT's Avatar
Maybe its just the 5.4 4v Im thinking of, but I know that will cost a assload of $$. Custom intake and exhaust is basically the only options. I've read a few swap threads where people mention them.
Old 03-08-2011, 10:42 AM
school boy
school boy's Avatar
my main concern would be the intake. the exhaust could be fabed up by a mom and pop shop, or at least the ones around here could
Old 03-08-2011, 11:10 AM
H0SS302
H0SS302's Avatar
I will stick with them... and ill be making an assload more torque than any 2v out there doing it. You can get a 5.4 shortblock for like 150 bucks... thats dirt cheap and will cost nothing to install other than the midpipe, and intake adapters(which are like 200 bucks). A 5.4 2v with ported heads and good cams with a HPS intake will do be teh shezzzyyyy
H0SS302 is offline
Old 03-08-2011, 02:01 PM
school boy
school boy's Avatar
if you do go with a navigator 4v 5.4, heres a option to use on a upper manifold. use a edlebrock adaptor with a 2v factory style plenium.
http://compare.ebay.com/like/3206643...=263602_304662
Quick Reply: engine swap
