How dumb was this? Left Cam in wrong.
Old 04-17-2011, 07:05 PM
  #21
99gstang
99gstang's Avatar
Originally Posted by Sash
dude how hard is to swap just the cams?
It all depends on ones level of skills and tolerance. It took approx 5-6 hours for me. there's more to it then just swapping cams.
CAI was removed.
The harness needs to be disconnected from coils, inj, etc.
Valve covers removed and cleaned.
Crank pulley, Water Pump pulley, A/C delete pulley, & tensioner pulley were removed.
Power steering reservoir & pump removed.
Front Timing covers has to come off and cleaned.
The tensioners and timing chains had to come off.
Chains were checked remarked.
#1 spark plug was removed to check TDC.
The cams & chains were lined up and tensioners torqued down.
The heads & block were cleaned for gaskets.
Then everything was bolted back together and torqued to specs.
The estimated cost ranges from $600-$900. for 7 hours labor.
99gstang is offline
Old 04-17-2011, 07:24 PM
  #22
Repzard
Repzard's Avatar
IMO....Not too dumb if you didnt do any damage.
Repzard is offline
Old 04-17-2011, 09:18 PM
  #23
99gstang
99gstang's Avatar
Thumbs up
That was cool
Thanks
99gstang is offline
GimpyHSHS
19
12-19-2023 01:12 PM
lincolnshibuya
07-05-2020 03:05 AM
patchshaffer
Tuner Central
10-05-2015 02:24 PM
uedlose
The Racers Bench
10-01-2015 08:31 PM
junior04
09-28-2015 10:53 AM
Quick Reply: How dumb was this? Left Cam in wrong.
