Procharger or Vortech?
#21
I like the engineering of a Vortech...I wonder why you can't run/buy a procharger without an intercooler??? hmmmmm
Notice guys running Vortechs without i/cs and the results...now slap an i/c on there and you have a blower setup just as/if not more efficient than that prochargers
btw, vortech offers self contained as well...dont know why people are so negative about tapping the oil pan anyway? Me personally, I would rather only change the oil once anyway
#22
Id think because their blowers heat soak without an intercooler, making them way less efficient
Ask 99% of the guys out there without an intercooler/aftercooler and running meth...see how they feel when you tell them they have a s/c kit thats not put together right.... and their temps are cooler and octane is higher than a car with just an i/c or a/c
#23
Im only pushing 6psi but my car seems to be fine without an intercooler Iplan on running one later bc i plan on running more boost through it but vortech support advised me that once I get to 10psi range with my kit then start looking into a intercooler. I called three diff times to get dif advice from different tech and they all three said the same. The Only issue I had was the belt and that was bc my tensioner that was already on my car/stock was bad. Replacement tensioner and gates belt no issues to this date. (knock on wood).
#24
What he said. Procharger does it right the first time and doesn't offer without it to lead to problems/ having to add meth. Vortech does not intercool the basic "cheap" kit and you get what you pay for low boost which is great for most street cars. When was the last time you saw a Vortech on a 750-1,500 horse engine?
Don't get me confused Vortech is great for mild performance street cars.
"btw, vortech offers self contained as well...dont know why people are so negative about tapping the oil pan anyway? Me personally, I would rather only change the oil once anyway"
Do you run 5w-20 in your rear end? Motor oil is not ideal for the transmission step down gears and bearings in the blower head unit. Self Contained head units can run the specific oil designed for the clearances in all of the gears and bearings. Even Vortech caught onto that and started offering it after Procharger came up with the idea.
#25
my "mild performance street car" will be pushing out 600rwhp through an auto, should be easy high 10 second car
our cars with 10psi can be maxed out even without an i/c
of course (which as you can see) you will have people nutswinging from procharger or vortech
when it comes to it, the truth is...no, you dont NEED an i/c to max these motors out, of course it will help, however you can buy a vortech kit, add meth, and you will have a safer motor and more power
And just to let you know, this is coming from a guy with an I/C AND meth
#26
#28
#29
#30
