cutting springs.
Old 05-23-2011, 10:14 PM
SVTeeshirt
SVTeeshirt's Avatar
Default cutting springs.
my buddeh is givin me some mach juan springs, which i assume are the same as about every other springs. I'm keeping mine uncut and cutting his lol, how much do i cut? from the top or bottom? thinking sligtly more in the back.
are iso's needed?
LMK newbs.
and non newbs.
and ruskies.
SVTeeshirt is offline
Old 05-23-2011, 10:38 PM
mrtstang
mrtstang's Avatar
Are they linear or progressive rate springs? I was going to do this a while back (did tons of research and whatnot) but decided to buy the right springs instead.
mrtstang is offline
Old 05-23-2011, 11:29 PM
PurpleIcedGT
PurpleIcedGT's Avatar
03GreyGT runs cut Mach Juan springs on his car, I'm pretty sure he runs them on the rear too. And I think he's running a 12.4 w/ TFS heads and cams at around 116mph. Those springs seem to do well for him. I can't imagine isos are needed, I never ran them on my H&R's so screw it I think you'll be fine without them. HPWrestler is the spring cutting God so he'll be able to tell you a little more in depth about how to and where to cut them. Pretty sure they should be cut from the top.
PurpleIcedGT is offline
Old 05-23-2011, 11:39 PM
2k1gt
2k1gt's Avatar
I'm running cut c-springs. You will need to cut from the top. As for how much, just experiment a little at a time.
2k1gt is offline
Old 05-24-2011, 04:25 PM
SVTeeshirt
SVTeeshirt's Avatar
a little at a time? I don't wanna keep cutting them and putting em on and taking em off. .
Old 05-24-2011, 07:55 PM
2k1gt
2k1gt's Avatar
I agree, nobody wants to do that, i'm just trying to save anyone from cutting too much off.
2k1gt is offline
Old 05-24-2011, 09:27 PM
945LSTANG
945LSTANG's Avatar
I cut mine from the bottom. Not sure if the Mach 1 springs are similar, but you want to cut which ever end is not flat. The flat part is usually up top and you DO NOT want to cut from that end.
945LSTANG is offline
Old 05-24-2011, 10:52 PM
SVTeeshirt
SVTeeshirt's Avatar
gotcha, i think it is the bottom.
Old 05-24-2011, 11:06 PM
Repzard
Repzard's Avatar
2k1gt.
I run Csprings in my 99 GT and I like them.but I must say the back kinda rakes.
Did you cut just the back or did you cut both front and back ?
I here alot of people cutting 1 coil off the backs.
Your GT seems to sit much lower than mine,I do have all ISO in ,wanted to avoid creaking.
My GT
@OP Sorry SVT didnt mean to HJ your thread in anyway but the C springs are pretty good if you want a stiffer ride with a nice drop
Repzard is offline
Old 05-24-2011, 11:08 PM
liljojo4711
liljojo4711's Avatar
i cut 1 coil from the rear and 2 from the front on stock gt springs
liljojo4711 is offline
Quick Reply: cutting springs.
