Wide band O2 gauge
Old 06-07-2011, 10:15 PM
Bmitchell373
Bmitchell373's Avatar
Default Wide band O2 gauge
So for those who have them. Do you run 2 or just 1? I'm just looking for in the future I want wideband for tuning. I was thinking about getting the gauge bezel with 2 pods in it so i can run 2 widebands.
Bmitchell373 is offline
Old 06-08-2011, 06:03 AM
ctgreddy
ctgreddy's Avatar
I just run one. when you get a car tuned at a shop they only use one, and half the time they just stick it in the tail pipe. I figured one is good enough.
ctgreddy is offline
Old 06-08-2011, 06:26 AM
uberstang1
Chupacabra
uberstang1's Avatar
Yep only running one here, just an FyI aem makes a new no weld bungfor 02 sensors all you do is drill a hole and its like a wormdrive clamp with a seal and a bungon it, works wonders for wideband installs.
uberstang1 is offline
Old 06-08-2011, 08:37 AM
sn95_331_GT_ yellow
sn95_331_GT_ yellow's Avatar
just using one, put in the X so i can get an "average" reading between both banks, works fine for me, just make sure its installed at the right angle, my buddy didnt follow the directions and his rusted out...
sn95_331_GT_ yellow is offline
Old 06-08-2011, 09:21 AM
Bmitchell373
Ok makes sense. Thanks Uber, ill have to check it out.
Old 06-08-2011, 09:42 AM
turbo232
turbo232's Avatar
the only car i know of that you would need 2 on ar the Z32 twin turbo 300ZXs. that is simply because they have 1 intake, turbo, intercooler and exhaust for each bank.
turbo232 is offline
Old 06-08-2011, 02:18 PM
mvr
mvr's Avatar
just installed my autometer wideband last week. installed it on the drivers side rear o2 bung (rears turned off in tune and i have lt's).
i put mine in the stearing column single pod. i also installed the cluster bezel dual pod with oil pres and vac/boost.
mvr is offline
Old 06-08-2011, 04:03 PM
sn95_331_GT_ yellow
we have an exhaust for each bank too...
guess what? i bet each side even has its own cam too!!!
Old 06-08-2011, 04:11 PM
turbo232
turbo232's Avatar
yeah....totally different than our. think of 2 seperate engines sharing a crankshaft working off the same computer.
turbo232 is offline
Old 06-08-2011, 04:23 PM
sn95_331_GT_ yellow
yeah, never got into the whole late 80's/early 90's over-engineered japanese crap...
next thing i know, you're gonna be asking about swapping a 13B into an SN95...
Quick Reply: Wide band O2 gauge
