Car is getting slower in 1/4
Old 06-26-2011, 09:07 AM
uberstang1
Chupacabra
uberstang1's Avatar
Originally Posted by Repzard
Decent numbers Bramas, what are you running for gears ?
I beleive hes running 4.30s
uberstang1 is offline
Old 06-26-2011, 09:20 AM
mustangmancp
mustangmancp's Avatar
Id have to say its weather...your 60fts were similar in two of your runs..so you can't really count that
mustangmancp is offline
Old 06-26-2011, 11:45 AM
TRUEBLUE3934
TRUEBLUE3934's Avatar
Hmmm...
The thing that stands out to me are your 1/8 and 1/4 trap speeds. You are picking up 26mph on the back end, which is a lot. The 1/8 traps are low for a car trapping 107 in the 1/4. This indicates to me that you could trap even higher in the 1/4 with a better 1/8 pass. I'm wondering if your shifting is a factor...
TRUEBLUE3934 is offline
Old 06-26-2011, 12:13 PM
turbo232
turbo232's Avatar
Originally Posted by TRUEBLUE3934
Hmmm...
well, in the video he is spinning a little from first to second. that will slow you down.
turbo232 is offline
Old 06-26-2011, 01:58 PM
tim2002gt
tim2002gt's Avatar
x2
Your losing alot of momentum when you spin early in the run. When I used to run Nitto dr's I would spin alot on the 1-2 and 2-3 shifts. I switched to MT dr's and my et's dropped .2-.3 consistently with no other changes.
edit: I should add that my 60' times also improved, but even on my runs where my 60' times were the same as with the Nitto's my 1/4 et still improved by .2-.3
tim2002gt is offline
Old 06-26-2011, 03:03 PM
Jay-rod427
Jay-rod427's Avatar
Have you changed your shift rpm? I know on my car any thing over 5600 and it picks up MPH, but loses ET. I have tried several times even on the same day back to back passes.
Jay-rod427 is offline
Old 06-26-2011, 03:18 PM
GTtony
GTtony's Avatar
Mabey U got fatterer over winter break. LMFAO...
Ive been avg 10 lbs a year since ive been married. Now im like 6'0 250lbs.
GTtony is offline
Old 06-26-2011, 05:20 PM
Moonshine
Moonshine's Avatar
Sounds like you've beat your clutch to shat and it's not biting as hard as it once was.
Just kinda sounds....slippy... Idk.
Moonshine is offline
Old 06-26-2011, 05:44 PM
TRUEBLUE3934
A little wheel spin can negatively effect your ET, but can actually increase your trap speeds. I guess the question there is how much wheel spin is he experiencing?
No question in my mind that he can trap 108-109mph with a better 1/8 pass. I agree that ET Street Radials are superior in grip to Nittos. A good DR is a very good way to address excessive wheel spin.
Old 06-26-2011, 06:57 PM
BraMas
BraMas's Avatar
I think it is my 1/8 mile also that is killing me. And my clutch is on it's way out maybe it is slipping in the lower gears and once it stops slipping after the 1/8 it is able to push me into the 107 traps. I did spin a little on me take off and 2nd gear change but I don't think enough to real kill my time plus my 60ft isn't that bad for being on street tires
BraMas is offline
Quick Reply: Car is getting slower in 1/4
