How to grease control arms/chassis lube??
Old 07-04-2011, 10:57 AM
avexhype
avexhype's Avatar
Default How to grease control arms/chassis lube??
Hi guys i have aftermarket Roush LCA's and FRPP UCA's. i was told that they need to be greased and inspected/maintained regularly (every other oil change). I had them for about 10k miles now and didn't know i needed to do anything to them.
How do i grease them or the bushing or whatever needs to be greased? and what kind of grease should i use? thanks
avexhype is offline
Old 07-04-2011, 12:33 PM
Moonshine
Moonshine's Avatar
Grab yourself a grease gun and a tube of red bearing grease. Attach the gun to the zerk on the control arm pivot point. Pump until you just see movement from the existing grease on the bushings. Done.
Moonshine is offline
Old 07-04-2011, 12:41 PM
H0SS302
H0SS302's Avatar
You can also use white lithium grease for a quick fix, but the correct way to do it is with a grease gun.
H0SS302 is offline
Old 07-04-2011, 04:48 PM
945LSTANG
945LSTANG's Avatar
Grease guns are cheap too so don't sweat it.
945LSTANG is offline
mrtrodonet
09-19-2020 03:12 PM
UrS4
10-03-2015 06:23 AM
breaking
10-02-2015 01:27 PM
ChampInSD
10-02-2015 04:55 AM
guitarman376
09-30-2015 05:54 PM
Quick Reply: How to grease control arms/chassis lube??
