word by mouth dyno
word by mouth dyno
I went to mustang week this year and didnt have time to get my Roush dynoed and since I know we have some smart guys/gals on these forums I decided to ask in here. Would have to drive 2 hours to get a dyno. Reputable one that is . What do you guys think my car would push? I have all thats in my signature. TB, Plenum and a CAI. Does not have a tune yet. And planned on getting 3.73 gears in the future. I do have a set of pulleys that I need to install that will boost it up alittle. Its a 04 Roush Stage 1. Pretty much a GT engine. Tell me what you think.
Sooo...
acufab tb, plenum, bbk cai= ??
same as above but plus 3.73 gears, tune and steeda ud pulleys= ??
Sooo...
displacement.
1 HP per cubic inch isn't difficult these days.
1.3 HP per cubic inch is tough. It takes compression, heavy breathing and most of all, VERY, VERY GOOD Fuela nd Ignition control.
Remember that there really is no such thing as HP, Its torque. We can measure torque, but HP is a theoretical calculation. You want HP? Build Torque. Create air velocity in your engine. If you increase flow capacity, you MUST turn higher rpm (or add displacement) to get the velocity back that supports torque. What have you done to promote flow AND permit high rpm operation? Added flow without added rpm is a torque killer.
superchargers, stroker kits, high rev cam kits with matching valvetrain (stock springs can only go so far)
displacement.
Remember that there really is no such thing as HP, Its torque. We can measure torque, but HP is a theoretical calculation. You want HP? Build Torque. Create air velocity in your engine. If you increase flow capacity, you MUST turn higher rpm to get the velocity back that supports torque. What have you done to promote flow AND permit high rpm operation? Added flow without added rpm is a torque killer.
You'll need a full HCI setup with every bolt on to push 300 rwhp. In some rare cases 300 rwhp has been done with cams alone, but it's very rare, and dynos vary. You could also bump the compression via different pistons and whatnot.
