Blown SN95 guys - question about FMIC's
You guys and your facts = fail.
The M90 on the Super Coupe blows UP in to a hat and leads down front on the driver's side to a small air to air, then back around on the same side and up to the lower intake up against the firewall.
To use a bigger front mount, you'll want to use an intercooler that has the inlet/outlet on the same end.
What Matt (other Matt) is looking for is an air to air that will fit behind the stock front bumper. I can't think of a single V6 member on this forum who has that. This section is probably gonna be more help.
check out this
https://mustangforums.com/forum/pipe...-finished.html
^this fmic might be a little big but cxracing sells different size ones along with piping
More facts: There was no 4.2L Super Coupe, it was a 3.8L pushrod. The 4.2L bottom end is from the F-150. It's a common V6 swap to get you up to 5.0L (pushrod) numbers without adding 2 sparkplugs.
Correct. 3.8 bored out .30 over, with forged internals, and 4.2 bottom.
check out this
Matthew
Sorry, I think Car2n beat you.
Look him up on Youtube. I'm thinkin' he runs a FMIC on his green stroker M90 V6.
Edit:
374rwhp and 431rwtq
http://www.youtube.com/watch?v=378q-C8pblA
Edit:
374rwhp and 431rwtq
http://cgi.ebay.com/ebaymotors/27-5X...Q5fAccessories
should fit behind your bumper without cutting. just measure just in case.
^heres my setup and i removed my support and used a 2x2 aluminum tubing. the i/c is 31x13x3
Edit:
374rwhp and 431rwtq
Edit:
374rwhp and 431rwtq
type in 2.5 intercooler on ebay and there will be several smaller i/c come up. imho, 2.5 pipeing should work fine for your setup. something like this:
Matthew
are you running a blow through maf or draw through setup. btw the 2.5 will hold a little higher boost preasure than a 3 inch setup but not by much. the extra volume of the 3 inch setup is why. another thing, most of the intercoolers in the size you want will be 2.5 inch inlet/outlet.
Matthew
a draw through is before the supercharger. the blow through is on the side between the supercharger and intake manifold. it wouldnt matter which size i/c piping you run with a draw through because its not ran with the i/c piping. just rember, running a draw through setup, the bypass valve/blow off valve has to recirculate the blew off air back between the supercharger and maf
