power guestimates on ysi 2v
I run a pretty similar build through a built auto...
I'm running a SI at the moment but pushing close to 20psi
I also run 93 octane with meth (not sprayed yet)
Other than that, pretty much close to the same build
I push out 516 at 5800rpms due to a converter/computer issue, when i can bring it up to 6500 I'm shooting for 550rwhp, then on meth I'm expecting to be close to 600rwhp through an auto, so I would sure hope he would be at 700rwhp
I'm considering swapping to a JT/YSI soon, let me know what he thinks
Also, intercool'd? 8/10 rib conversion, cog? what blower pulley? what crank pulley?
your build is something like what I want when i get my motor in my car. would a v2strim at say 20lbs produce similar numbers to yours? I'm not sure if an SI is better than a v2 strim, or what not.
yes it is intercool'd, 8 rib setup, He's gonna try a 2.8 blower with his stock crank pulley and depending how much boost that makes, he'll swap to an o/d balancer if needed.
You will be WAY overspinning an S trim at 20psi. That thing will heatsoak like crazy. MY SI is honestly pretty much maxed out the way it is, and I would say if your looking to be in the 20psi range look into a T/JT trim. But again, dont get carried away by psi....worry about impellar speed. A JT is rated at 60,000. What would your pulley combo be and I can help ya figure out what headunit would be the most efficient for ya
Mike
as long as it's still making power past 6500 rpm then it will be spun that high. not sure how these cams are gonna like the high rpms tho so we'll have to see. I was somewhat under the impression that the jt/ysi were very similar blowers.
Knowing all this i'm sure he'll swap to an o/d balancer depending on how high he takes it. it will most deffinitely be ran with the strim at first, so we'll get to figure out how high he can take the motor, then figure out the pulley combo to make good power. he is not chasing a number. the more horsepower the better no matter how high it is, as long as it's under 1000 lol.
