Advantages/ Disadvantages of IRS..
#51
^ Good question....
The SRA will pick up some weight for sure, as the UCA's are the only thing removed and certainly don't weigh nearly as much as a PHB or WL with TA.
The one big thing of which I don't know, in regards to the IRS, would be the RC. My guess is it would be the center of the pumpkin, as it is stationary. Interesting thread, to be sure
Jazzer
Jazzer
#52
The difference in weight is 75lbs, as measured by a guy in the link posted by stangalator. This is consistant with what I have heard over the years. BUT.... much of that weight is no longer sprung, so the springs/shocks don't have to work soo hard to control it. This is a big advantage and should not be under estimated.
I would agree that much of the weight gained with building an IRS would be the brace. I doubt that upgrading axles, going CO's and improved bushings would make much difference either way.
Jazzer
Jazzer
#53
Jazzer
Jazzer
#54
I don't know where the extra weight is concentrated, but the IRS has a set of twin-"A" arms (not sure of their specific names) and is probably most of it. The dogbone is probably only a couple pounds, never weighed one.
Jazzer
Jazzer
#56
This is a plus for a hardcore road/track dood/doodette
Griggs racing adds neg. camber to their SRA's, via some custom welding work on the ends of the axle. I had actually debated doing this myself, but have more rear grip that I could have ever imagined.
Jazzer
Jazzer
#57
How can you add camber to a SRA via welding the end of the axle housing? seems like the differential would have to be custom to aim the axles upward a little to get that to work right?
#58
#59
Jązzer
#60
They cut-off the ends of the axle tubes and move it upward like 3/4" or so. Just enough to avoid the axle itself from hitting the top/inside of the tubes. Weld up the openings on the top/bottom of the tubes and vwallah.... er, walla.... viola I can't spell voilą, dammit! You've now got like 1* of neg camber out back
Jązzer
Jązzer
