Advantages/ Disadvantages of IRS..
Old 09-12-2011, 06:19 PM
  #61
Jazzer The Cat
Retired Moderator
Jazzer The Cat's Avatar
Naaaaa... so long as the welds are good, the axles aren't going anywhere. Hell, they do this for the hardcore race cars they build.
Jazzer
Jazzer The Cat is offline
Old 09-13-2011, 05:33 AM
  #62
uberstang1
Chupacabra
uberstang1's Avatar
Originally Posted by turbo232
wouldnt that make it weaker though?
A good welder can make things stronger than original welds on compenets from the factory.
uberstang1 is offline
Old 09-15-2011, 06:33 PM
  #63
stangalator
stangalator's Avatar
no but the axles, hubs and thus wheels would need to be tilted at a 1 degree angle too. wouldnt that wear the differential funny since the axles would now be coming into the differential at 1 degree above parallel.
stangalator is offline
Old 09-15-2011, 10:03 PM
  #64
zinsavage123
zinsavage123's Avatar
Originally Posted by Jazzer The Cat
If you put a '99~'04 Cobra rear-end in your car, it is most certainly IRS
how though they say the 99-04gt is not IRS but suddenly the 31spline makes it IRS all the 31spline is is extra splines to make it harder to snap/break vs the 28spline right? Its the same axels as the 28spline so I'm confused here???? how is the 99-04 gt not IRS but both axels and rear is the same minus the 31spline lsd?????
zinsavage123 is offline
Old 09-16-2011, 07:03 AM
  #65
teej281
4.6L Section Moderator
teej281's Avatar
If you're talking about just the differential itself, adding that will not make it an IRS. Adding the subframe and the differential housing and control arms as well as everything else from an 03 cobra rear makes it an IRS.
teej281 is offline
Old 09-16-2011, 07:13 AM
  #66
Jazzer The Cat
Retired Moderator
I didn't realize you meant JUST adding 31 spline axles.... no, certainly NOT an IRS. This is why I "qualified" my post by saying "If you put a '99~'04 Cobra rear-end in your car, it is most certainly IRS"
The SRA cannot be converted to IRS or at least not without the most major modifications you can imagine.
Jazzer
Old 03-13-2013, 03:09 PM
  #67
DcievingSnake
DcievingSnake's Avatar
So I've read this entire thread and I am no closer to making a decision. I'll be making around 900hp and taking the car to the track occasionally. Will the IRS hold up to the punishment or am I going to have to swap it out for a "stick and wheels" ?
DcievingSnake is offline
Old 03-13-2013, 05:55 PM
  #68
uberstang1
Chupacabra
uberstang1's Avatar
More details on this 900hp build
Old 03-13-2013, 06:00 PM
  #69
dwtjr3
dwtjr3's Avatar
+1 more info?
dwtjr3 is offline
Old 03-14-2013, 08:56 AM
  #70
DcievingSnake
99 Cobra MMR 1000S 5.0 Stroker, MMR stage 3ported heads bronze guides SS valves, Hellion 76mm single turbo kit, turbo smart eBoost2 controller, AEM wideband kit, dual pump setup good to 1000hp, I am hoping to get right around 900hp out of this and from what MMR and Hellion tell me this won't be expecting too much out of this combo. Any help as far as the rear setup and suggestions would be appreciated.
Quick Reply: Advantages/ Disadvantages of IRS..
