Advantages/ Disadvantages of IRS..
Old 09-02-2011, 06:57 PM
Soldier GT
Soldier GT's Avatar
Default Advantages/ Disadvantages of IRS..
Hey all.. Got alot of plans/hopes/dreams this winter for the stang and one of them is maybe installing a IRS. I was just wondering what you guys thought about it. Is it worth the money? Any input would be much appreciated!
Soldier GT is offline
Old 09-02-2011, 09:19 PM
Jay-rod427
Jay-rod427's Avatar
Awesome if you want to carve corners... You will have to do some upgrading to not tear **** up with your power if you put a sticky tire on it and launch hard.
Money shouldn't be to bad as you can usually find a trade for a Cobra guy wanting a SRA for drag racing. Take your time and find the right deal.
Jay-rod427 is offline
Old 09-02-2011, 10:26 PM
PurpleIcedGT
PurpleIcedGT's Avatar
Soldier one of my goals in life is to buy this car from you. Adding an IRS would decrease my offer price 98%.
Cmon my man!!!!!!
PurpleIcedGT is offline
Old 09-03-2011, 12:13 AM
Harryman2002
Harryman2002's Avatar
Do the switch! The sra only advantage of the sra is its better to launch with. So unless you go to the track all the time why not switch? It rides much better and with a good set of springs and shocks/struts it'll handle like its on rails too.
No reason not to switch in my opinion.
Harryman2002 is offline
Old 09-03-2011, 09:17 AM
teej281
4.6L Section Moderator
teej281's Avatar
http://www.svtperformance.com/forums/member.php?u=9457
03 Cobra - Sonic Blue
KB 2.8H, 6spd, IRS "stock halfshafts"
9.82@139
1.47 60ft
6.32@111.26 1/8th
This is a member's signature over on SVTP. IRS's launch just fine and when setup correctly they have a much reduced chance of breakage.
Anyways, as we've talked about before, the swap is definitely worth it! Handling and ride STOCK are worlds better, and any modification to it the better the ride and handling gets(save for lowering springs, they make it handle better but harsher ride...COILOVERS FTW!). As with any suspension style, they can be upgraded. Bushings and springs(if you get an 03 cobra IRS with stock bilsteins) goes a LONG way. If youre ever up in PA or northern MD, give me a shout. I'll take you for a spin in my car. You'll see why I made the swap real quick.
I definitely would not say that I got 5th place at the MW auto-x on driver skill. Especially since it was the first time I ever did it.
teej281 is offline
Old 09-03-2011, 10:06 AM
school boy
school boy's Avatar
soldier, when you do this swap, go ahead and get all the little things bracing wise. like i have the mm flsfc, lower torque box braces, rear irs braces, diff brace, and the irs already had poly bushings and 373s withe h&r race springs. i have had zero wheel hop running 315 nt05 and a i/c vortech. i really like mine but i havent been able to drive the car much. like teej said, the ride and handling is much better plus polished tail pipes with the irs look awsome! good luck with which ever route you take!
school boy is offline
Old 09-03-2011, 11:45 AM
99 GT vert
99 GT vert's Avatar
9.82@139
1.47 60ft
6.32@111.26 1/8th
. The sad thing is he is pulling the irs out this winter and going sra. The only disadvantage to an irs is it is expensive to completely build it.
99 GT vert is offline
Old 09-03-2011, 11:48 AM
teej281
teej281's Avatar
Yea, buying a brace or an actual supportive cover for the diff is a good idea as well. The cover is better as the brace in my mind is just a band-aid. Get some real support there and you'll be good.
And +1947475893490378458 to the polished tailpipes...sexy sexy!
Evan, yea. It sucks that he is swapping out the IRS for the SRA. I mean when there is nothing else you can do to your setup short of adding more power to go faster than go to an SRA, than I guess thats what you have to do! His car is going to go faster, but when you're deep into the 9's, anything faster is really an accomplishment.
teej281 is offline
Old 09-03-2011, 12:44 PM
LilRoush
LilRoush's Avatar
Depends on what you want out of it. Stock SRA vs stock IRS, the IRS will ride nicer for you. Ford's IRS isn't the best design for one. If you are thinking of performance handling, I'd go with a properly built 5 link from Steeda instead. After looking into it for myself, the 5 link will out perform the IRS swap.
LilRoush is offline
Old 09-03-2011, 01:06 PM
teej281
teej281's Avatar
Tell that to the cobra r guys
Spirited street car, you cant beat an IRS. Modify the IRS with bushings and the ride and handling gets worlds better, as well as launching and being able to put the power down.
teej281 is offline
Quick Reply: Advantages/ Disadvantages of IRS..
