if possible post up a pick taken from the front of your car high up looking down. I'll photoshop it real clean, also with your hood done between the lines outside the scoop. That would look great.
Cool !
I am a semi-retired mechanical engineer turned data/embedded system engineering consultant--not an artist by any measure...
The front wheel looks like that because you need an alignment
LOL I don't think an alignment which will adjust caster/camber will fix his wheel positionally front to back. I wanna believe something is either bent, or some geometry is out of whack. I remember this being a topic a while back and I don't mean to bring the debat up again.
I would look into commerical sign companies that do utility vans etc. They may have a gloss or matte black vinyl they could put on in one piece in a couple hours or so.
