Finally have a master plan for the car - 2000 Mustang GT
Old 09-26-2012, 10:21 AM
  #71
trailor
trailor's Avatar
http://www.uprproducts.com/mustang-n...-cable-96.html
here's the first one I found. if you can find a frpp or dealership replacement for close to that price, i would go for it.
trailor is offline
Old 09-26-2012, 10:46 AM
  #72
Syracuse315
Syracuse315's Avatar
Looks good to me. Btw, any reason why I wouldn't want to think about reusing my stock cable (115k miles on it)?
Also, any benefit of running a triple hook quadrant vs the double hook?
Syracuse315 is offline
Old 09-27-2012, 01:51 PM
  #73
trailor
trailor's Avatar
To answer your first question, I assumed that you were dead set on replacing the stock cable. If it's not noticeably stretched or frayed, I see no issues with reusing it.
Second question, the difference between the two is a patent. I think Steeda had a patent on the double hook quadrant, so to get around it, UPR made a third, useless hook. I forget which one you're supposed to use, but do some research and you should easily figure it out. CliffyK actually did a write up about the triple hook quadrant, and he eventually had problems with it fraying his clutch cable. I, like him, have sanded the edges down and did not notice any fraying when I checked it after about 4-5k miles, so perhaps he missed a spot, or perhaps I'm just lucky and he is not?? I dunno if you would hafta do this with the double hook quadrant or not, but if the edges aren't smooth where the cable rests, I would sand them down as well. Since I haven't had any issues with UPR triple hook quadrant, I would recommend it since its cheaper, just heed the warning to sand down the edges wherever the cable makes contact.
trailor is offline
Old 09-28-2012, 12:42 AM
  #74
Syracuse315
Ok, sounds like a good plan. I saw CliffyK greased the quadrant as well.
In regards to the clutch/flywheel, HDX (clutch) and FRPP (flywheel) seems like the usual suspects for clutch replacement (along with Centerforce Dual Friction, but that's double the cost). How much am I looking at for shop install, $300-400?
Old 09-28-2012, 01:10 AM
  #75
Syracuse315
Should I look into replacing the clutch fork/other items while I'm in there as well?
http://www.americanmuscle.com/frpp-clutchfork-9604.html
Old 09-30-2012, 11:41 AM
  #76
trailor
trailor's Avatar
I dunno about shop costs or replacing the clutch fork. I have suspicions that my clutch fork is bent/warped (either that or my cable is stretched), so whenever my clutch goes, I will be replacing mine.
trailor is offline
Old 10-01-2012, 11:48 PM
  #77
Syracuse315
May not be a bad idea either ^^.
Found a pretty useful site for this as well:
http://www.aa1car.com/library/2003/bf50332.htm
Old 10-02-2012, 04:56 PM
  #78
UPRSharad
Former Sponsor
UPRSharad's Avatar
Thanks for the review!
The clutch fork isn't really a wear item. I've gone through quite a few clutches and even a few transmissions, but I've never needed to replace the clutch fork.
UPRSharad is offline
Old 10-03-2012, 12:02 AM
  #79
Syracuse315
What are the symptoms of a bad clutch fork?
01blackgtconv
08-14-2015 04:50 PM
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
daytooday
08-11-2015 09:22 AM
01blackgtconv
08-10-2015 01:25 PM
Quick Reply: Finally have a master plan for the car - 2000 Mustang GT
